Attached is a sample pic. The red part of the tape is touching/grinding the video drum, I had to remove it. Is this a normal occurrence or is this a sign that something is wrong with the video drum like out of alignment?
No, it's certainly not normal. More likely the cassette compartment is misaligned or something is bent/broken and allowing the cassette to come too close to the drum.
I have been getting a lot of video dropouts from my 8mm tapes. Could this the source of my problem? I have attached a clip.
JVC: do I need a Dynamic Drum for VHS tapes recorded w 80/90's camcorders?
By LouGee in forum Video ConversionReplies: 13Last Post: 10th May 2016, 09:40 -
Digitising 8mm video tapes – 3 scenarios – which is best?
By danvideodiary in forum Capturing and VCRReplies: 21Last Post: 8th Aug 2014, 20:09 -
Trouble with old 8mm tapes
By James77 in forum Capturing and VCRReplies: 5Last Post: 14th May 2014, 00:47 -
Old 8mm tapes LP help
By Robocop in forum RestorationReplies: 14Last Post: 22nd Dec 2012, 14:33 -
Capture Analog 8mm Video 8 Tapes to DV - What equip will produce best Qual
By koop in forum Capturing and VCRReplies: 7Last Post: 5th Apr 2012, 00:36
