Sample: https://www.sendspace.com/file/ja2zzx
This is an NTSC DVD that appears to have every 4th frame duplicated, as well it appears to have interlacing lines (to my eye), but DGIndex calls the video progressive.
Using MeGUI + AVISynth I'm trying to figure out what can be done. I'm assuming decimate might be able to rid the duplicate frames, but is there away to remove the apparent interlacing lines?
Is this as simple as QTGMC + decimate? Or, is this hard interlacing and may either require special treatment, or, perhaps nothing can be done about it at all?
Thanks in advance~
				Results 1 to 14 of 14
	Someone may have a better idea and I don't really know how it got the way it is, but QTGMC seems to clean it up reasonably well. I don't think it's actually interlaced though. Something like this maybe....
 TDecimate()
 QTGMC()
 SelectEven()
 crop(20, 14, -20, -14)
 Spline36Resize(832,468,1,0,-1,0)
 LSFMod()
	It's not interlaced. Looks like 24 fps source with duplicated frames to make it 29.97 and some blends crept in along the way.
	Yeah, I'd do something similar to hello_hello, maybe QTGMC in progressive mode after removing the dupes. It doesn't look like real interlacing to me, either, but maybe aliasing.
	QTGMC(InputType=1)
 QTGMC(InputType=2)
 QTGMC(InputType=3)
 All the above are progressive modes. I can't remember the exact differences. You'd need to check the help file. It doesn't work for your video though. I tried InputType=1 and it made the aliasing worse. One of the other progressive modes might do slightly better but I'm pretty sure de-interlacing followed by SelectEven() to remove the repeated frames will give you the best result.
 Edit: It was annoying me, not being able to remember, so I looked it up.
 This script is designed for deinterlacing and so by default expects an interlaced clip. However, much of its operation concerns the reduction of horizontal shimmering. It is possible to use the script to remove similar shimmer from a progressive clip by using the InputType setting. InputType=1 is used for general progressive material that contains less severe problems. InputType=2,3 are designed for badly deinterlaced material with considerable horizontal artefacts. These modes drop half the fields and recreate an interlaced stream from the others, which is then treated in the normal way. Mode 3 differs from mode 2 only in that it complements field parity of the input. Generally mode 1 will retain more detail, but repair less artefacts than modes 2,3. You may consider setting TR2 to a higher value (e.g. 2 or 3) when repairing progressive material.Last edited by hello_hello; 3rd Jan 2017 at 15:38.
	Gory details.
 http://avisynth.nl/index.php/QTGMC#Progressive_Input
	The video isn't interlaced at all. It's just been poorly deinterlaced. And from the blending artifacts it was probably originally PAL video.
	The way I read it, mode 2 removes every second scanline in a frame (described as "dropping half the fields"), they're replaced by interpolating new scanlines from the remaining ones, then the video is de-interlaced. I assume if mode 2 keeps all the even numbered scanlines, mode 3 must keep the odd ones.
 TR2 (0,1,2,3) Temporal linear smoothing radius used for final stablization / denoising. Increase for smoother output
 The defaults for many settings change if you change the speed preset, and the default speed preset is "slower" which sets TR2=1.
 You can see the currently used settings by previewing a script like this:
 QTGMC(InputType=1, ShowSettings=true)
 If you were to specify the fast preset you'd see it changes to TR2=0
 QTGMC(InputType=1, Preset="fast", ShowSettings=true)
 You can over-ride individual settings independently of any speed preset.
 QTGMC(InputType=1, Preset="fast", TR2=3, ShowSettings=true)
 The presets are a preconfigured trade off between speed and quality (default "slower").
 Preset (string) Sets a range of defaults for different encoding speeds. Select from "Placebo", "Very Slow", "Slower", "Slow", "Medium", "Fast", "Faster", "Very Fast", "Super Fast", "Ultra Fast" & "Draft"
 If you want extra denoising, you use the EZDenoise function with a value greater than zero. The value sets the denoising strength.
 QTGMC(InputType=1, Preset="medium", ShowSettings=true, EzDenoise=1.5)
 The EzDenoise function has it's own speed presets somewhat independent of the main speed presets. The default is "fast" which is pretty much all I ever use. There's no need to specify either speed preset unless you want to use something other than the defaults.
 QTGMC(InputType=1, Preset="medium", ShowSettings=true, EzDenoise=1.5, NoisePreset="medium")
 NoisePreset (string) Automatic setting for quality of noise processing. Choices: "Slower", "Slow", "Medium", "Fast", and "Faster", Default is "Fast"
 For most presets the defaults are: NoiseProcess=0, Sigma=2.0, NoiseRestore/GrainRestore=0.0, ChromaNoise=false, DftThreads=EdiThreads, ShowNoise=false
 In "Placebo", "Very Slow" some defaults change: NoiseProcess=2, GrainRestore=0.3, NoiseRestore=0.1
 EZDenoise and EZKeepGrain set automatic values for NoiseProcess, NoiseRestore/GrainRestore and Sigma
 Denoiser, DenoiseMC, NoiseTR, NoiseDeint and StabilizeNoise settings are determined by NoisePreset
 If using manual settings be sure to override *all* the values you are interested inLast edited by hello_hello; 4th Jan 2017 at 05:42.
	Something like this will reduce the aliasing better and will be much faster than QTGMC:
 You could always use QTGMC after this.Code:Mpeg2Source("War-No More Trouble.d2v", CPU2="ooooxx", Info=3) TDecimate() Deblock_qed() # fine tune this Spline36Resize(width,288) # back to PAL field height nnedi3(dh=true) # double the height with smooth edges Spline36Resize(width,480) # back to NTSC frame height Sharpen(0.0, 0.6) # sharpen vertically
	Thanks, @jagabo. By "you could always use QTGMC after this." do you mean that I would run your script, and run a new script on the processed video based on your script? Or, simply add in QTGMC after your last line? Either way, would I still want to / need to indicate Selecteven in order to keep fps in check?
  Removing duplicate framesBy Colek in forum Video ConversionReplies: 7Last Post: 9th Oct 2015, 13:40
  Script to detect duplicate frames?By kieranvyas in forum EditingReplies: 30Last Post: 22nd Aug 2015, 21:01
  Live Action & Animation combination; duplicate frames and jagged linesBy Rugratskid in forum DVD RippingReplies: 4Last Post: 10th Aug 2015, 21:41
  What if source has and duplicate frames and is interlaced and moreBy rhaz in forum DVD RippingReplies: 17Last Post: 15th Jun 2014, 07:17
  Deleting duplicate frames on clipBy Jonz in forum EditingReplies: 4Last Post: 9th May 2012, 22:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 haha...
  haha...
