MKVToolNix 9.7.1 I installed the latest version but the mkvmerge GUI short cut is missing from this release? Had Mkvtoolnix 8.30. installed thanks in advance
MKVToolNixGUI
The complaints about the changing of the GUI ended long ago, and we'd rather not hear about it again. -
You are unbelievably behind the times. As in nearly a year and a half behind. Version 8.3.0 was the last version that included the mkvmerge GUI.
2015-08-15 Moritz Bunkus <moritz@bunkus.org>
* build system: removal: the switch »--without-mkvtoolnix-gui« has been removed. There are only two GUIs left in the package: the Qt-enabled mkvinfo and MKVToolNix GUI. Both are enabled by default and can be disabled with the option »--disable-qt«. In that case only the text-mode version of mkvinfo is built, and the MKVToolNix GUI is not built at all.
* Removal: all support for wxWidgets has been removed. This means that the mkvmerge GUI (mmg) has been removed and that mkvinfo now only supports a text-mode and a Qt-based interface.
* build system: bug fix: fixed Qt platform plugin detection on MacOS.Do or do not. There is no "try." - Yoda -
zcool2016,
The new one takes a little getting used to, but it's much better than the old GUI. I don't know what shortcuts the installer installs as I always download the portable version, but the old GUI shortcut pointed to mmg.exe which no longer exists. The new version should have a shortcut pointing to mkvtoolnix-gui.exe. If it installed a shortcut labelled MKVToolNixGUI or something similar, that's the one you want.
The new GUI had a tab labelled "merge", but the name has changed to "multiplexer" now. Same thing, different name. If memory serves me correctly both mmg.exe and mkvtoolnix-gui.exe were installed during the transition to the new GUI, but it's just MKVToolNixGUI now.
Need help using MKVtoolnix
By Larold in forum SubtitleReplies: 8Last Post: 6th Apr 2016, 07:00 -
MKVToolNix
By hardy in forum Newbie / General discussionsReplies: 23Last Post: 9th Nov 2015, 10:57 -
Mkvtoolnix
By Freelife2345 in forum Video ConversionReplies: 1Last Post: 27th Nov 2014, 16:39 -
mkvtoolnix problem
By aLTERLENIN in forum Video ConversionReplies: 9Last Post: 6th Jun 2014, 05:04 -
mkvtoolnix
By Harshad Patil in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2013, 07:17
