i followe instructions on burning a vcd but nothing was burned on my cd-r. It did create 2 output files : .cue and a .bin . it said everything was ok and it recognized my burner.....what did i do wrong?? Do i have to format the disc first , I didn't??
Do i have to do something with the .bin file? What is the .bin file? .cue file?help!
niel
On the Main screen, beside CD Writer: is a drop-down box with your CD drives in them. Is your burner selected?
Then, beside the drop-down box, there is Simulate and Burn. Did you make sure simulate was not checked, and burn was checked? If neither are checked, only the image file (the .bin) is made and you can burn that with CDRWin.
Also, check the Settings --> CDRDAO section. Ensure all the settings there are correct.
Output Size of PAL VCD Rendered In Sony Vegas Pro 10 Is Too Huge
By LeHuoXuan in forum Authoring (VCD/SVCD)Replies: 8Last Post: 28th Feb 2011, 22:40 -
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
Possible to output hdmi and optical output on the ps3??
By mrswla in forum DVD & Blu-ray PlayersReplies: 10Last Post: 3rd Feb 2009, 16:17 -
VCD Easy
By kshavo in forum Authoring (VCD/SVCD)Replies: 10Last Post: 12th Feb 2008, 15:43 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 06:33
