  1. Hello,
    I just got the 203. I notice some 4k mkv videos do stream and some don't.
    The only difference I can see is the codec - HEVC main 10@L6.1@main does NOT stream - however, HEVC main 10@L5.1@main does stream.
    How do I change this? Can I use mkvtoolnix to select another hevc codec?
  2. You cannot change the level using mkvtoolnix. Needs re-encoding (ffmpeg, VidCoder, HandBrake etc.).
  3. Thanks - I'll download handbrake and give it a try.
    Edit - I just downloaded handbrake - didn't see an option to keep the original 4K resolution although I think I could create one - not sure where to change the l6.1@main to L5.1@main.
