I'm not sure of this forum is the right place to ask these qustions, but I'll try it anyways.
I have a video clip that contains moving objects. I want to put text on top of the moving objects and move them along with the objects. Since the frame of the video is not standing still, it's difficult to program the movement of the text so that it always stays on top of the moving objects. Therefore, I imagine that the easiest solution would be to control the text's movement with my mouse pointer as the movie is running and the objects are moving. More specifically, I'm looking for a tool in a video editor that let's you attach the position of a text line to the mouse pointer position and then lets you record the movement of your mouse pointer as you manually move it around. The result I want is a pirece of text that moves in the same trajectory as the recorded movement of my mouse pointer.
I have no idea if this is easily achievable, but I thought I'd give it try here since I didn't find the answer on google. Also, this is just for a one-time use so I'm limited to free video editors and video editors with trial periods.
Thanks in advance for your answers!
Normally something like this is done with a motion tracker. Simple shots can be done with a 2d tracker
Essentially you track the objects, and link the text to the motion data, so that the text "sticks" to the object(s)
Doing it by "hand" will typically be jittery and wobbly, even if you do it frame by frame and take a long time manually
The type of tracker you would use, depends on the object motion(s) and the camera motion(s) and the scene specifics . If there are more complex motions, camera movements, parallax, perspective, then you need to use more complex trackers
Common software would be Adobe After Effects (I think there still is a free trial), Hitfilm (there is a free version but not sure if it has motion tracker) , Blender (completely free, but learning curve is steep and GUI is not very intuitive) -
You could use AegiSub. You can't follow the motion of an object with the mouse as you are asking, but as poisondeathray pointed out, that would be jittery anyway. But you can program using simple XY coordinates where you want the text to appear. You can even make the text follow the rotation of an object.
I've never tried a motion tracker, but it sounds like fun if I ever needed such a thing.Do or do not. There is no "try." - Yoda
Subtitle workshop 6.0b mouse pointer lags while i wait SW to start
By pavjos777 in forum Newbie / General discussionsReplies: 0Last Post: 6th Nov 2014, 05:13 -
Youtube video choppy during camera movement for some viewers
By Skysaberer in forum Video Streaming DownloadingReplies: 4Last Post: 9th Apr 2014, 22:15 -
PotPlayer - How to unhide pause/play menu on mouse movement in full screen?
By tahayassen in forum Software PlayingReplies: 3Last Post: 30th Jan 2014, 21:02 -
Controlling playlist inside MP4 container
By SanFrancisco234 in forum Video ConversionReplies: 6Last Post: 3rd Nov 2013, 15:00 -
Video Shows Mouse In Bag Of Big Mac Rolls
By zzyzzx in forum Off topicReplies: 2Last Post: 21st Jan 2012, 00:35
