I just got a Mac Mini, and one of the first things I wanted to do was try out Quicktime.
I cannot even find a menu for it, it just gives me the option to record the screen. Also, I wanted to reactivate my QuickTime Pro key since I still have it saved.
I am brand new to Mac, and sadly already I'm lost.
Thread moved to the mac forum where you can get more help.
QuickTime (the underlying multimedia framework) is different from QuickTime Player (the media player).
The modern player (version 10.x, for Mac OS X 10.6 and later) is fundamentally different from the older player (upto version 7.x) in functionality. Both can be installed at the same time. Only the older QuickTime Players could be upgraded to Pro. There is no Pro registration for QuickTime Player v.10.x. I doubt the serials for Windows work on Mac OS X. -
Yes and to clarify & update:
The underlying Media framework for MacOS used to be Quicktime, but that was deprecated years ago. Now MacOS and iOS are both using AVFoundation.
Quicktime Player/Pro 7.x runs on Quicktime api, while Quicktime Player 10.x runs on AVFoundation. Which is partly why you can have both installed.
Also, AVFoundation is crippled because Apple chose not to support either backward compatible Apple codecs (meaning only QT 7.x can play them unless they get transcoded), nor allow 3rd party codec development (leaving you with a very small, Apple-centric subset to choose from). And QT 10.x is crippled because it lost many of the editing and ALL of the exporting features of its earlier cousin.
And NO, 7.x pro serials for Win QT are different than the Mac QT ones. I know - I had to purchase both at one point in my business.
Instructions for accessing ROM content for Win and Mac
By sdsumike619 in forum Authoring (DVD)Replies: 15Last Post: 13th Feb 2016, 15:49 -
Problems using vlc on mac, doesn't look as good as quicktime?
By Ilikebreadsticks in forum Newbie / General discussionsReplies: 4Last Post: 25th Jul 2015, 17:05 -
Mac - Making a new compilation with bare-bones menu
By dragonstout in forum DVD RippingReplies: 1Last Post: 5th Jul 2014, 08:25 -
Handbrake settings for Quicktime (Mac)
By flips01 in forum MacReplies: 7Last Post: 5th Aug 2012, 14:08 -
Mac OS X Lion QuickTime Player Choppy Audio
By zBernie in forum Software PlayingReplies: 2Last Post: 17th Feb 2012, 20:05
