  1. Hi cats,
    kindly I need help to do this operation:
    My attached input.avi is recognized by ffmpeg as 1920X1088 instead of 1080, so to "normalize" this input avi file is necessary to crop the source with a line of this kind:
    -vf crop=1920:1080:0:0
    after this I need to scale it (jet 1920x1080) from hd to sd using a thing similar to this line
    -vf yadif=1:tff,scale=720:576,unsharp=luma_msize_x=3:luma_msize_y=3:luma_amount=0.8,colormatrix=bt709:bt601,interlace -sws_flags lanczos+accurate_rnd
    but the input have to be treated with pc level using a thing similar to this line
    -vf scale=interl=1:in_range=pc:out_range=pc
    I try various commandline but I get some error, please can anyone help me to do this 3 operation? I get alwais a HD output and/or not the tv-->pc levels
    Is there a way to do this 3 operation in a unique commandline? thanks
  2. Try -vf yadif=mode=1:parity=0,crop=h=1080:y=0,scale=w=720: h=576:in_range=pc:out_range=tv,interlace,setsar=16/11
    Also remember to enable proper interlaced encoding, parity and range in the encoder.
  3. Code:
    IF "%FullHD%"=="1" v:\automazioneclip\core\ffmpeg.exe -y -i %4 -i "%audiosource%" -vf yadif=1:tff,crop=h=1080:y=0,scale=w=720:h=576:in_range=%inRange2%:out_range=%outRange2%,unsharp=luma_msize_x=3:luma_msize_y=3:luma_amount=0.8,colormatrix=bt709:bt601,interlace -pix_fmt yuv420p -c:v libx264 -profile:v main -level:v 3 -g 33 -bf 2 -crf 15 -flags +ildct+ilme -top 1 %AudioSettings% %anFlag% -aspect 16:9 "%~n1_Mp4_SDdownscale_420PortaAPorta_%panState%.mov"
    thanks, it works!
  4. Originally Posted by marcorocchini View Post
    thanks, it works!
    IF "%FullHD%"=="1" v:\automazioneclip\core\ffmpeg.exe -y -i %4 -color_range 2 -i "%audiosource%" -vf yadif=1:tff,crop=h=1080:y=0,scale=w=720:h=576:in_range=%inRange2%:out_range=%outRange2%,unsharp=luma_msize_x=3:luma_msize_y=3:luma_amount=0.8,colormatrix=bt709:bt601,interlace -color_range 1 -pix_fmt yuv420p -c:v libx264 -profile:v main -level:v 3 -g 33 -bf 2 -crf 15 -flags +ildct+ilme -top 1 %AudioSettings% %anFlag% -aspect 16:9 "%~n1_Mp4_SDdownscale_420PortaAPorta_%panState%.mov"
    May work better, i would also unsharp before resize and i would specify for scaler flags too for example:
    scale=w=720:h=576:sws_flags=spline+accurate_rnd+full_chroma_int+full_chroma_inp:sws_dither=0:in_range=1:out_range=1
  5. Hi c*t, please consider this isput source: C0007.MXF
    https://dl.dropboxusercontent.com/u/39871584/C0007.MXF
    this is an interlace 1440x1080 25fps video file
    I need to downscale it, at the best quality, to SD 720x576 and upscale to HD 1920X1080
    target file should be MP4 H.264 (x264) 4:2:2 for both
    ffmpeg.exe -y -i c0007.mxf -color_range 2 -vf yadif=1:tff,scale=w=720:h=576:sws_flags=spline+accurate_rnd+full_chroma_int+full_chroma_inp:sws_dither=0:in_range=tv:out_range=tv,unsharp=luma_msize_x=3:luma_msize_y=3:luma_amount=0.8,colormatrix=bt709:bt601,interlace -color_range 1 -pix_fmt yuv422p -c:v libx264 -profile:v high422 -level:v 3 -g 33 -bf 2 -crf 15 -flags +ildct+ilme -top 1 -an -aspect 16:9 outSD.mp4
    ffmpeg.exe -y -i c0007.mxf -color_range 2 -vf yadif=1:tff,scale=w=1920:h=1080:sws_flags=spline+accurate_rnd+full_chroma_int+full_chroma_inp:sws_dither=0:in_range=tv:out_range=tv,unsharp=luma_msize_x=3:luma_msize_y=3:luma_amount=0.8,interlace -color_range 1 -pix_fmt yuv422p -c:v libx264 -profile:v high422 -level:v 3 -g 33 -bf 2 -crf 15 -flags +ildct+ilme -top 1 -an -aspect 16:9 outFullHD.mp4
    is this correct?
  6. Originally Posted by marcorocchini View Post
    is this correct?
    Seem to be OK - however you may consider to use zscale https://ffmpeg.org/ffmpeg-filters.html#zscale instead sws_scale - accordingly to some people it should provide better resize quality.
    zscale=d=ordered:f=spline36:r=full:w=iw/2:h=-2
  7. ah ok but my commandline how should be become?
  8. HD
    -vf yadif=1:tff,zscale=w=1920:h=1080:f=spline36:r=full,unsharp=luma_msize_x=3:luma_msize_y=3:luma_amount=0.8,interlace
    SD
    -vf yadif=1:tff,zscale=w=720:h=576:f=spline36:r=full,unsharp=luma_msize_x=3:luma_msize_y=3:luma_amount=0.8,colormatrix=bt709:bt601,interlace
