Hi c**s
please consider my commandline:
In this way I create a .mxf that have in the channel audio 1 the R channel of the test.wav input file, and in channel audio 2 the L channel of the test.wav input file.Code:ffmbc.exe -i test.avi -i test.wav -tff -target xdcamhd422 -an output.mxf -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 1:0:0:0:1:0 -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 1:0:1:0:2:0 -acodec pcm_s24le -ar 480000
Now I would like to add another test2add.wav file to add in channel 3 and 4 of the output.mxf file created with ffmbc
PLEASE CAN ANYONE HELP A CAT? THANKS! AND HAPPY NEW YEAR
				Results 1 to 10 of 10
	Mr. c**t, you can do it with ffmpeg -filter_complex "[1:a][2:a]amerge".
 This means you would have to do whatever you need to do in ffmbc (is that even a thing any more?)
 then post-process with ffmpeg. ffmbc don't do amerge.
 Here's a working command line (batch version, with line breaks)Naturally, you need to set -channel_layout to whatever is appropriate.Code:ffmpeg ^ -an -i "video.mp4" ^ -vn -i "audio1.wav" ^ -vn -i "audio2.ac3" ^ -map 0:0 -map 1:0 -map 2:0 ^ -filter_complex "[1:a][2:a]amerge" ^ -channel_layout quad ^ -c:v copy -c:a pcm_s16le ^ "mergetest.mov"
	I know but ffmpeg give output files that cannot back into the camera (I have a Sony PDW-F800 camcorder) or in the appropriate xdcam deck (pdw-HD1500) but ffmbc can do it using the version 0.7.4: so ffmpeg can produce a file that seems identical to the ffmbc one but that is not playable in xdcam deck. If you want play .mxf files in xdcam deck you are forced to using ffmbc 07.4
	mmmmmmmmm maybe yes  maybe maybe
 the xdcamhd422 .mxf structure is like this:
 General
 Complete name : V:\TeatroRomano\video\C0001.MXF
 Format : MXF
 Commercial name : XDCAM HD422
 Format version : 1.2
 Format profile : OP-1a
 Format settings : Closed / Complete
 File size : 37.1 MiB
 Duration : 5 s 160 ms
 Overall bit rate : 60.3 Mb/s
 Encoded date : 2016-12-29 22:53:32.000
 Writing application : SONY Opt 1.22
 Video
 Format : MPEG Video
 Format version : Version 2
 Format profile : 4:2:2@High
 Format settings, BVOP : Yes
 Format settings, Matrix : Custom
 Format settings, GOP : M=3, N=12
 Format settings, picture structure : Frame
 Format settings, wrapping mode : Frame
 Codec ID : 0D01030102046001-0401020201040300
 Bit rate mode : Constant
 Bit rate : 50.0 Mb/s
 Width : 1 920 pixels
 Height : 1 080 pixels
 Display aspect ratio : 16:9
 Frame rate : 25.000 FPS
 Standard : Component
 Color space : YUV
 Chroma subsampling : 4:2:2
 Bit depth : 8 bits
 Scan type : Interlaced
 Scan order : Top Field First
 Compression mode : Lossy
 Bits/(Pixel*Frame) : 0.965
 Stream size : 30.8 MiB (83%)
 Color primaries : BT.709
 Transfer characteristics : BT.709
 Matrix coefficients : BT.709
 Audio #1
 Format : PCM
 Format settings, Endianness : Little
 Format settings, wrapping mode : Frame (AES)
 Codec ID : 0D01030102060300
 Bit rate : 1 152 kb/s
 Channel(s) : 1 channel
 Sampling rate : 48.0 kHz
 Frame rate : 25.000 FPS (1920 spf)
 Bit depth : 24 bits
 Stream size : 726 KiB (2%)
 Locked : Yes
 Audio #2
 Format : PCM
 Bit depth : 24 bits
 Locked : Yes
 Audio #3
 Format : PCM
 Bit depth : 24 bits
 Locked : Yes
 Audio #4
 Format : PCM
 Bit depth : 24 bits
 Locked : Yes
 Audio #5
 Format : PCM
 Bit depth : 24 bits
 Locked : Yes
 Audio #6
 Format : PCM
 Bit depth : 24 bits
 Locked : Yes
 Audio #7
 Format : PCM
 Bit depth : 24 bits
 Locked : Yes
 Audio #8
 Format : PCM
 Bit depth : 24 bits
 Locked : Yes
 Other #1
 Type : Time code
 Format : MXF TC
 Time code of first frame : 00:00:00:00
 Time code settings : Material Package
 Time code, striped : Yes
 Other #2
 Type : Time code
 Format : MXF TC
 Time code settings : Source Package
 Other #3
 Type : Time code
 Format : SMPTE TC
 Muxing mode : SDTI
 Time code of first frame : 00:00:00:00Last edited by marcorocchini; 2nd Jan 2017 at 03:57.
	Individual mono streams eh... OK, channelsplit seems to work here: Code:ffmpeg ^ -vn -i "stereo1.wav" ^ -vn -i "stereo2.ac3" ^ -filter_complex:0 "channelsplit=channel_layout=stereo" ^ -filter_complex:1 "channelsplit=channel_layout=stereo" ^ -channel_layout:0 mono ^ -channel_layout:1 mono ^ -channel_layout:2 mono ^ -channel_layout:3 mono ^ -c:a pcm_s16le ^ "splittest.mov"
 mmmmm c*t*
 I need to "integrate" a sort of (with your modified as say in the other post):Code:ffmbc074.exe -y -i %4 -i tempAudio_PAIR1_ForFFmbc.wav -tff -target xdcamhd422 -an "%DestFolder%/%~n1_%panState%HDlinerare_xPDWF800.mxf" -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 1:0:0:0:1:0 -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 1:0:1:0:2:0 -acodec pcm_s24le -ar 48000
 so thatCode:ffmpeg.exe -y -i input.avi -vf yadif=1:tff,scale=1920:1080,unsharp=luma_msize_x=3:luma_msize_y=3:luma_amount=0.8,colormatrix=bt601:bt709,interlace -sws_flags lanczos+accurate_rnd -an -pix_fmt yuv422p -c:v rawvideo -f rawvideo |
 but it don't workCode:ffmpeg.exe -y -i input.avi -vf yadif=1:tff,scale=1920:1080,unsharp=luma_msize_x=3:luma_msize_y=3:luma_amount=0.8,colormatrix=bt601:bt709,interlace -sws_flags lanczos+accurate_rnd -an -pix_fmt yuv422p -c:v rawvideo -f rawvideo | ffmbc074.exe -y -i - -i tempAudio_PAIR1_ForFFmbc.wav -tff -target xdcamhd422 -an "%DestFolder%/%~n1_%panState%HDlinerare_xPDWF800.mxf" -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 1:0:0:0:1:0 -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 1:0:1:0:2:0 -acodec pcm_s24le -ar 48000
  Add audio track to M4V that already has a variable number of audio tracksBy ppomes in forum LinuxReplies: 5Last Post: 5th May 2015, 20:21
  ffmpeg: add audio track to a mp4By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 2nd Sep 2014, 10:28
  MULTIAVCHD - can't add additonal audio trackBy Joep97 in forum Authoring (DVD)Replies: 6Last Post: 15th Jul 2013, 21:35
  How to add second audio track into a MKV file?By WJohn in forum Newbie / General discussionsReplies: 7Last Post: 12th Oct 2012, 08:14
  Add an audio track or replace the audio track of an AVIBy abrafax in forum Newbie / General discussionsReplies: 9Last Post: 1st Oct 2012, 15:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
