Hi , im trying to extract the subtitles from a mp4 video file . By extract i mean Rip them so i can have a copy of them on my desktop to later use them on a clean version of the video file . The subtitles however are hard coded so I was hoping you could help me out with something . I did some searching and I found out that SubRip can rip the subs from .avi files so i'm trying to convert all of my mp4 video files to .avi first so then I can rip the subs later with SubRip 1.56.1 . Will that do ?
check with mediainfo:
if it has 2 streams (video & audio), it means the subs were burned in... which means there are no subtitles that can be extracted. totally different story if these were mkv files. -
You can try AviSubDetector. I believe there are other software that does the same for hard coded subs.
Alternatively you could look on one of the many srt subtitle sites to check if it's already available. Depending on your jurisdiction this may or may not be legal.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
No need to convert. You can import an avs script directly into Subrip.
As blud7 said, you can give a try to AviSubDetector, Videosubfinder or esrxp.
By the way, in this case the process is called OCR, not extracting
You have the 'Holy Grail solution' right here: https://www.youtube.com/watch?v=VHsUfqqAkWY
The output isn't perfect, but you just have to correct stuff instead of starting from 0. I automatically generated a lot of time codes with this. It takes minutes instead of hours.
Been searching for this solution for years and years.
Pay close attention to the video and all its details. You're welcome.
DVD(Video_ts) with subs to a file with hardcoded subs?
By hech54 in forum SubtitleReplies: 3Last Post: 30th Aug 2016, 15:45 -
How to create a 'highlighted' subtitle to cover over hardcoded subs
By cinesimon in forum SubtitleReplies: 6Last Post: 5th Jun 2015, 01:26 -
extract the timing of hardcoded subtitle?
By sendspellme in forum SubtitleReplies: 7Last Post: 15th Jan 2015, 16:02 -
Problem with playing AVI with hardcoded subs
By RPB in forum Newbie / General discussionsReplies: 5Last Post: 6th Jan 2014, 14:25 -
converting mkv or avi to mpeg2 - hardcoded subs not visible
By rogmath in forum SubtitleReplies: 2Last Post: 2nd Nov 2013, 17:01
