I have many .mts files from my camcorder that are short clips. I was wanting to merge them into one .mts file. I realized I could do this easily with MKVToolNix.
The problem is when I try to add a .mts file (i mistakenly forgot to select it earlier) to the new all-in-one .mts file I just created. MKVToolNix gives me an error that the audio formats are different. It's like MKVToolNix changes the audio, though I thought it doesn't re-encode.
The biggest difference I noticed is the Audio ID and Audio Codec are different for each.
The resulting file's audio is as follows:
Audio for merged short clips using MKVToolNix
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 21mn 41s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -33ms
Stream size : 39.7 MiB (3%)
Default : Yes
Forced : No
Audio for original short clips:
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1mn 12s
Bit rate : 256 Kbps
Bit depth : 16 bits
Stream size : 2.21 MiB (0%)
Doing a search on Google, I couldn't find the significance of the two different formats and why they couldn't be appended together.
Any suggestions?
Results 1 to 14 of 14
I'd guess (because I couldn't find any info I was confident I understood) that MKVToolNix is rewriting the codec ID or something similar when muxing. When you later attempt to append another M2TS segment it sees it as not containing the same audio. Therefore if you remux the additional M2TS part with MKVToolNixGUI and attempt to append the new MKV instead, it should be successful. That's just a theory though, and could be a load of nonsense....
What happens if you start afresh and redo all of the files you need in the compilation including the one you forgot initially? Could a setting in your Camcorder has changed? MKVMerge GUI doesn't re-encode video or audio so not sure what's happening here. https://mkvtoolnix.download/doc/mkvmerge.html
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Your right, it works when I append two video files that have already been appended using MKVToolNix. So, it's obvious some reencoding or something that changes the audio format is transpiring during the remux process.
I would suggest you post a full MediaInfo report of the original mts files that you are muxing into a MKV container - once again MKV Tools does not re-encode Audio or Video so the problem is elsewhere. If it was capable of re-encoding the whole process would take much longer in time and you would be able to convert from one audio format to another which of course it cannot. All it does is wrap the video and audio and subtitles and chapters etc in a MKV container.
The codec ID has changed. At least according to the MediaInfo info in the first post. I've no idea if that's something MKVToolNix did or if it's just the way MediaInfo is interpreting it.
I'm not saying the audio itself has changed or been re-encoded, but something may have changed when remuxing as MKV. -
maybe there is a difference in the 2 source mts files - a MediaInfo report of both file would help to track down what is happening.
As a quick experiment I tried remuxing an MKV as an M2TS file with TS muxer. The codec ID for the AC3 changed from 129 to A_AC3, according to MediaInfo. I tried appending the MKV to the M2TS file and when I did the AVC video wouldn't append. That's probably expected behaviour, but the AC3 appended fine on it's own, so I didn't manage to prove anything there.
I have attached the two logs from MediaInfo: One is the original straight from my camcorder (Original.m2ts). The other is the remuxed version from MKVToolNix (Remuxed.m2ts).
MKVToolNix seems to always default to the .mkv extension for output, so I always try to change it so it matches the original file extension; .m2ts in this instance. I notice the file size for the remux file is smaller than the original. Shouldn't they be the same size if nothing is being changed?
Original file size: 767 MB
Remuxed file size: 728 MB -
Maybe keep all your components as m2ts and do all the appending in https://www.videohelp.com/software/tsMuxeR the resulting file will have the same output suffix naturally. Then use MKVMerge to put in a MKV container.SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Thank you for confirming the obvious for me
I thought that was probably the case after further testing, but it's nice to know for certain. I haven't used TsMuxer in a while that I forgot all about it. Thanks for the reminder and the clarification!
Cant merge mkv video and audio with mkvtoolnix?? any ideas?
By kjy in forum Newbie / General discussionsReplies: 5Last Post: 6th Jan 2016, 11:37 -
Settings to use for audio for a video with 3 types of clips
By avz10 in forum AudioReplies: 5Last Post: 29th Aug 2015, 18:28 -
Synchronising audio and video of 300 AVI clips
By avz10 in forum AudioReplies: 39Last Post: 13th Dec 2013, 12:53 -
How to change the format of a slideshow containing video clips and photos
By avz10 in forum Authoring (DVD)Replies: 2Last Post: 5th Sep 2012, 09:38 -
from hi definition video clips to NTSC and PAL dvd format.
By shh1cd in forum Video ConversionReplies: 7Last Post: 6th May 2012, 20:26
