Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. It's a shot in the dark but let's try: my Onkyo AV receiver doesn't support ARC. Does some intermediary device exist? Now I have an optical cable running from the TV to the AV reciever, but I'd rather use a single HDMI cable to simply things: I'll buying a media box soon and want to use as little as possible cables.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    The media box will (likely) need an audio feed directly to the Receiver. Routing through the TV will typically cause an audio delay/lip sync issue.
    And I've not seen a device to implement ARC, but that would introduce even more cables (ie: HDMI (from the TV) to the device and then HDMI and audio cables from the device to the Receiver).
    Google is your Friend
