Some years ago I bought Honestech VHS to DVD 5.0 deluxe.
I created DVDs from VHS successfully, but I also managed to produce mpg files.
But I've forgotten how I created the mpg files, and can't find anything in the user documentation to help.
It might come under "Publish .... iPad, iPhone and iPod .... Apple iPad AVC - (high quality)" but there may be other options.
Can anyone assist, please?
	I do not know this program but I can not see any 'Publish' option from the user-guide.
 Are you sure you used the capture software to create the mpeg >> most can do it as an intermediate step. The 'Advanced Mode' offers some different formats - appears to default to 'DVD Single Layer'. The user guide is not so specific as to what other formats are on that drop-down.
	Use 'dvdshrink' to select the part you want & save it as vob. Simply rename said (*.)vob to (*.)mpg. Use any of many converters to mp3.
 Years ago I would input audio from my vcr to the computer & (use whatever media recorder was in W-98, I forget!) record to wav file, & then convert to mp3, actually, back then, burned to CD (cda). Later converted to mp3. Got a song or two (from movies) by Leonard Cohen that were never on record or CD.Yes, no, maybe, I don't know, Can you repeat the question?
  Honestech VHS to DVD 2.0 - Software not recording although VHS is playingBy emma1994 in forum Capturing and VCRReplies: 1Last Post: 24th Nov 2016, 18:11
  hONESTECH vhs TO dvd-5.0By Dirtytennisball in forum Capturing and VCRReplies: 7Last Post: 2nd Dec 2015, 14:37
  honestech vhs to dvd 7.0, not working rightBy webber99 in forum Capturing and VCRReplies: 7Last Post: 27th Feb 2015, 12:22
  Problem with Honestech VHS to DVD conversionBy KaiserD2 in forum MediaReplies: 12Last Post: 15th Nov 2013, 16:32
  Honestech vhs to dvd 5.0 - vhs capture loses picture after 5 minutesBy NJA in forum MediaReplies: 1Last Post: 19th Jun 2013, 11:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
