Hi,
It's a bit of a mystery to me. Vicoder and Handbrake don't seem to have any built-in choices for the size of srt subtitles, and I'm not sure how to make this happen. It's also a mystery that some SRT subtitles end up larger than others. What determines the size? Anyone have any ideas?
Martin HAck
Just a few months ago, I had exactly the same frustration you are having now. So I will share with you what I have learned since then.
The resolution of the source and destination videos determine how big the .SRT subs will be in relation to the picture size. There is no provision to change it manually.
If you want to have more control over the size of your subs, as well as fonts, colours, positioning, etc., use AegiSub and import your .SRT file. You can open your source video right in AegiSub to see exactly what the subs will look like over top of it, and play with the font sizes, etc. to get what you want. Use its style manager to create a handful of different looks that you use frequently. Once you're happy with it, save it as AegiSub's .ASS format. Then combine the .ASS subs with the video file in an .MKV container using MKVToolNix. Then in VidCoder just select that subtitle stream instead of importing an .SRT file.
There's only a very small learning curve if you've never used AegiSub. I've only been using it for about 3 months, and I could do it in my sleep now (and in fact, sometimes I do). Made me really wish I had started using it years ago.Do or do not. There is no "try." - Yoda
Handbrake not detecting subtitle file?
By Nazomon in forum Newbie / General discussionsReplies: 1Last Post: 3rd Oct 2014, 02:07 -
Handbrake subtitle support
By MindController in forum SubtitleReplies: 6Last Post: 19th Apr 2014, 18:03 -
Pirate preset in Handbrake or ViCoder
By indijay in forum Video ConversionReplies: 11Last Post: 28th Feb 2014, 15:38 -
Extract subtitle with handbrake
By blue90210 in forum DVD RippingReplies: 6Last Post: 16th Nov 2013, 14:19 -
switchable subtitle in mkv files (Handbrake)
By livevil2702 in forum SubtitleReplies: 0Last Post: 28th Jun 2012, 13:35
