I'm attempting to repair an old video in which the video and audio are exactly the same length, but only the beginning and end of the video are synced. The video slowly goes out of sync and then near the middle slowly starts to go back into sync, so a simple audio delay/stretch will not work.
I have never encountered this type of sync issue before and I would think I'd need some sort of 'multi-point' audio stretching software with the ability to also show a video track. Does such a tool exist? Anyone encountered this issue before and what kind of solutions did you use to correct it?
I can convert the audio/video to any format needed. I am familiar with most AV software including Virtual Dub/Vegas/etc.
Anyone have any advice?
Then split the audio into as many parts as you need to pound it into shape. Go scene-by-scene if you have to. I have done this sort of work syncing Super 8 projector sound to frame-scanned video, and while tedious, it does work.
Adobe Audition (at least the old 3.01 version I'm using) has a "Gliding Stretch" effect that changes linearly from one ratio to another. But that may be even more work unless you have a perfectly linear variation.
Might wanna check for video frames that are corrupted near the sync issue,that will put the audio out of sync for a while and then it will resync due to another frame issue.
VirtualDub audio out of sync, other video players all in sync
By a1s2d3f4 in forum Newbie / General discussionsReplies: 7Last Post: 11th Apr 2016, 22:36 -
Batch Video Joining (same video at beginning and end, different middle)
By mrloudcry in forum EditingReplies: 2Last Post: 11th Dec 2015, 19:18 -
How to delete frames in the middle of a mkv (audio and video)
By zaerdy in forum EditingReplies: 3Last Post: 27th Jun 2015, 12:53 -
fixing audio sync without changing the video/audio quality of mp4 video
By aruwin in forum AudioReplies: 3Last Post: 8th Aug 2014, 00:10 -
Need a simple tool to sync up badly out of sync audio and video
By CompVid in forum EditingReplies: 16Last Post: 26th May 2013, 07:55
