I read Hauppaugr USB-Live2 is also good. http://www.hauppauge.com/site/products/data_usblive2.html
Results 31 to 34 of 34
Does anyone remember the retail price of ADVC110 and ADVC300 when it first came out?
Pyro ADS had problems with original firmware.
For revision C of the device there was firmware upgrade done at the factory that fixed the issue.
My unit never had it installed, but my work around was simple.
I just sent the signal through a Panasonic DMR-ES10.
The sync circuits of the ES10 did a great job, so I never lose a frame.
The second problem of my unit is that from time to time it inverted the fields.
I finxed this with Avu synt and virtual dub.Top 10 ways to amuse a geek:
1. Make a list of the top 10 ways to amuse a geek.
10. Use binary. -
Dumb question about Canopus ADVC110
By Foxhack in forum Capturing and VCRReplies: 3Last Post: 28th Dec 2015, 18:22 -
Can ADS Pyro A/V Link work with Windows Vista?
By rijir2001 in forum Capturing and VCRReplies: 2Last Post: 17th Nov 2014, 19:26 -
Can you significantly improve from Canopus ADVC110?
By gevorg in forum Capturing and VCRReplies: 6Last Post: 3rd Apr 2013, 06:43 -
Sound from only one speaker - Canopus ADVC110
By swoooosh in forum Capturing and VCRReplies: 1Last Post: 17th Nov 2012, 10:13 -
This is why iPads are so popular
By TreeTops in forum Off topicReplies: 4Last Post: 9th Jun 2012, 16:45
