Does anyone here use Magix Movie Edit Pro? I've used it for years, but am now at the point where I want to do a little more with my editing and the chopping stop and go during editing playback has made it too hard to continue. I've considered using Sony Vegas, but I wanted to know if other Magix users had the same issues I've had.
When I'm editing a video, I drop video files into the time line so that I can arrange, crop video, add fades and some effects, add titles, and add music. When I'm playing it back to edit particular points, it will stop, skip, lag, and be very choppy while watching it to see where I need to add or change things in the video. The video files I'm using are sometimes large, about 850 megabytes, and others are smaller, about 250 megabytes, and the files types are typically .mp4 and .mov. The larger video files are usually like 5 minutes plus, but I crop most of it out and only use about 4 or 5 seconds of each of the video files. Is it because the files are large that it lags? Even though I crop out the unwanted portion and am only using a few seconds of the video? Should I be cutting the video down to what I need and rendering them to smaller files?
I guess in the past, the files were typically smaller, but the more I record video today, the longer some of the files are and that could be what the issue is. My computer is plenty powerful enough, and I know that isn't the issue. It has to either be the software or video files that are too large.
I'm still very new to editing and am trying to learn. Hoping that this forum is a great source of help.
Thanks!
your opinion that your computer is powerful enough may not cut it. what are the actual specs? an i7 with a high end vid card and at least 3 hard drives? magix was always a lower tier consumer video editing program with glitches and bugs. now that magix bought vegas, movie edit pro will probably vanish. you might check out whether magix offers a 30 day free trial of vegas like sony used to.
I own Magix Movie Edit and use it every now that then. I use it for capturing sometimes, and I use it for audio editing/merging quite often too.
Can't burn blu-ray discs using either Magix Edit Pro 2016 or ImgBurn
By Steelerfan43240 in forum Authoring (Blu-ray)Replies: 5Last Post: 20th Apr 2016, 15:01 -
Magix Movie Edit-Chapter markers "disappers"
By Mållgan in forum Authoring (DVD)Replies: 0Last Post: 17th Aug 2013, 07:00 -
Movie Edit Pro MX Plus-using an own menuimage
By Mållgan in forum Authoring (DVD)Replies: 1Last Post: 11th Dec 2012, 14:08 -
Magix Movie Edit Pro Plus 17 + transporter effect [solved]
By timcs in forum EditingReplies: 1Last Post: 29th Oct 2012, 15:39 -
Best settings when editing videos with Vegas 11 Pro to publish on Youtube
By siopilos in forum EditingReplies: 9Last Post: 13th May 2012, 11:57
