Mine takes ~4 hours to convert a cd sized worth batch of .vob files to .mpg so I can burn it to VCD. Is there any way to speed up the process a bit, without getting a new processor? Does it take this long for everyone else as well ?
~Lyzic
Without knowing what CPU you have, and what settings you use, and a few other things, any comparison would be useless.Originally Posted by LyzicAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
lyzic,
no, unless you're the developer of tmpg and know a few things to
release (i mean, improve, he, he... )
But, you'll need to take another look at your process/methods and see
where you can improve "effeciancies"
Also, your "encoding" method will have to be looked at as well.
* "rate control mode", ie CQ vs. CQ_VBR vs. CBR, etc.
* size, ie 352x480 vs. 720x480 vs. 352x240, etc.
* framerate, ie 23fps vs. 25 vs. 29
* color space, ie RGB vs YUY2 vs. YUV, etc.
* filters and their highest/lowest values you set them to, etc.
* ivtc, 32pulldown, inverse32, etc.
* GOP ?
* DCT
* motion search
* stream type, etc. etc. etc.
* not to mention your video stream BEFORE importing to TMPG may
have some speed affect, ie frameseving, using filters, etc prior
to importing to TMPG, etc., etc.
Increasing more RAM ain't gonna give must improvement at all, if you can
notice it at all.
But, in a whole, the all the above, is bascially an algorithem. Jugle these
around, (algorithem'ly speaking) and you could yield more speed, be it
1% or 5% or 20%
But, only in increasing your CPU will you really notice it, but it you increase
it to say, 100 or 200Mhz, then you wont really see much either ?? ie,
over-clocking, etc. your motherboard.
These are just a few to give you an idea of improvement adjustments.
-vhelp -
something else you can try is under environmental options, increase the task priority.
or, do what a lot of people do...set it up before sleepy time, and let it work overnight--that way, even if it takes 4 or 6 hours, you won't be bothered by the encoding time
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 14:24 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
