Results 1 to 30 of 42
  1. Capturing Memories dellsam34's Avatar
    Jan 2016
    I want to compress my huge HuffUYV caps to a modern video format or codec that allows me to keep the video interlaced, keep the same video resolution and keep the chroma sub untouched (4:2:2), What do you guys advanced users use? I read in different threads to avoid NLE software such as Adobe premiere and Sony vegas, Is there any other alternatives? or there is no such thing as custom as I wanted it?
  2. Originally Posted by dellsam34 View Post
    It depends on what the goal is, or how you are going to be using it . Why are you doing this ?
    i.e. did you want to compress it smaller, but don't mind quality loss ? or lossless compression just more compressed than the huffyuv compression ?
    What device / software target(s) / platform(s) ?
  3. Capturing Memories dellsam34's Avatar
    Jan 2016
    Just for device playback compatibility such as nVidia shield, LG smart TV from USB drive, preferably no loss, Little loss is ok, but MPEG-2 or DV like loss no. My goal is not really compressing as I mentioned, What I meant is a more compatible codec that keeps the video proprieties unchanged.
  4. Likely , they won't support 4:2:2 playback . Most "smart" TV's , android devices, console or bd players etc... only support 4:2:0
    What was your original source prior to huffyuv ?
    Aug 2010
    San Francisco, California
    Do you care about the loss if you can't see it? Try encoding AVC with x264 at crf = 17. AVC/h264 is very widely supported.
  6. Capturing Memories dellsam34's Avatar
    Jan 2016
    Analog S-VHS, Hi8 and VHS PAL/NTSC
  7. Capturing Memories dellsam34's Avatar
    Jan 2016
    I do see the loss from uncompressed AVI to MPEG-2 or DV I've done it and witnessed it myself. How good AVC compared to the two I mentioned?
  8. Originally Posted by dellsam34 View Post
    yes, or just to be sure even lower CRF , like 13 to 15 because of low light , gradients etc., and then to cut off peaks, like no more than 15000 to 20000, that is more than enough
    x264.exe --crf 14 --vbv-bufsize 17000 --vbv-maxrate 17000
  9. if you insist on 4:2:2 perhaps add --output-csp i422
    but I doubt if you see any difference and you would have playback problems using non PC devices
    I forgot you have interlaced video, if bottom field first (if top field first then --tff), then for 4:3 NTSC:
    x264.exe --crf 14 -bff --sar 8:9 --tune grain --vbv-bufsize 17000 --vbv-maxrate 17000
    or try:
    x264.exe --crf 14 --bff --sar 8:9 --tune grain --output-csp i422 --vbv-bufsize 17000 --vbv-maxrate 17000
    if different resolution or system, follow this table:
    if %ar%==4:3 if %h%==480 if %w%==720 (set sar=8:9)
    if %ar%==4:3 if %h%==576 if %w%==720 (set sar=16:15)
    if %ar%==16:9 if %h%==480 if %w%==720 (set sar=32:27)
    if %ar%==16:9 if %h%==576 if %w%==720 (set sar=64:45)
    if %ar%==4:3 if %h%==480 if %w%==704 (set sar=10:11)
    if %ar%==4:3 if %h%==576 if %w%==704 (set sar=12:11)
    if %ar%==16:9 if %h%==480 if %w%==704 (set sar=40:33)
    if %ar%==16:9 if %h%==576 if %w%==704 (set sar=16:11)
  10. Capturing Memories dellsam34's Avatar
    Jan 2016
    What software to be used and does it give you options to keep video interlaced and same resolution?
  11. Capturing Memories dellsam34's Avatar
    Jan 2016
    Would the Philips player be able to play the files if 4:2:2 is kept?
  12. I dont think so. I might be wrong though, but chipsets in common video players do not play 4:2:2 videos
    software like ripbot for example where you can modify x264 command line
  13. or you can try this dmfs to mP4-DVD.zip , you need to install Avisynth
    is your HUFFYUV RGB?
    Then create huffyuv.INI in notepad:
    path_destination      :C:\Destination
    path_temp             :C:\Temp
    x264_variables        :--crf 14 --bff --sar 8:9 --tune grain --keyint 60 --output-csp i422 --vbv-bufsize 17000 --vbv-maxrate 17000
    nero_variables        :-lc -cbr 256000
    write avisynth script between lines, no loading clip line in there!
    ConvertToYUY2(matrix="rec.601")
    grab your huffyuv.avi and that created INI and drop them onto that _Avi to MP4.BAT
    you modify command line as you want, no input output there or avisynth script
  14. Capturing Memories dellsam34's Avatar
    Jan 2016
    Oh I see, Scripting which I'm little unfamiliar with but I'm a fast learner if I get the time, So is this all new? Because back then when editing using scripts there was no MPEG4.
  15. It makes no difference, avisynt script outputs always uncompressed video, it is encoder, in this case x264 that encodes that output, and that text file above is just INI file , it is made up thing just for that sort of batch script, that INI file is just a file where locations for files are stored, command lines for video and audio and avisynth script. That batch (having BAT extension , if you cannot see extensions in your PC enable it in windows) uses x264 encoder to encode video and Nero AAC encoder to encode audio and MP4muxer to get MP4 container for those streams. For that batch , you do not need any knowledge, you just drop those two files (that INI and your avi) onto that BAT and it should (in theory) work creating MP4 . I would try it, but I do not have huffuyv codec in PC right now. It works with DV avi videos, that I tried.
    you can try that ripbot first, but you'd need avisynth installed and some other stuff as well, but there is more x264 front-end software's around, not sure if you can fully modify command line there, megui for sure, but it is a bit complicated, or you can try ffmpeg command line as well, but I do not use ffmeg, not sure what command line would that be at the moment.
  16. Capturing Memories dellsam34's Avatar
    Jan 2016
    it makes no difference, avisynt script outputs always uncompressed video, it is encoder, in this case x264 that encodes that output
    you can try that ripbot first, but you'd need avisynth installed and some other stuff as well, but there is more x264 front-end softwares around, not sure if you can fully modify command line there, megui for sure, but it is a bit complicated, or you can try ffmpeg command line as well, but I do not use ffmeg, not sure what command line would that be at the moment.
    I might've installed Avisynt at one point of time, never had time or motivation to play with it, I remember sending a sample to one of the DigitalFAQ forum members to show me an example of de-interlaced and color correction filters applied to the sample and the edited file came out fantastic. Anyway to answer your question about RGB or not here is some spec of one of the files:
    Video
    Format : HuffYUV
    Format version : Version 2
    Codec ID : HFYU
    Duration : 3 min 56 s
    Bit rate : 56.3 Mb/s
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 5:4
    Frame rate : 25.000 FPS
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Scan type : Interlaced
    Bits/(Pixel*Frame) : 5.426
    Stream size : 1.55 GiB (97%)
  17. Capturing Memories dellsam34's Avatar
    Jan 2016
    Oh by the way how to set the aspect ratio to 4:3 with HuffYUV in vertualDUB?
  18. it is YUV huffyuv so hopefully AviSource loads 4:2:2 huffyuv avi ok without needing to some extra parameters because that batch creates loading line automatically , you cannot write it in that INI, so your INI would be, now I noticed it is PAL, not NTSC, assuming also 4:3 so SAR is 16:15 :
    path_temp             :C:\Temp
    x264_variables        :--crf 14 --bff --sar 16:15 --tune grain --keyint 60 --output-csp i422 --vbv-bufsize 17000 --vbv-maxrate 17000
    you might capture video as tff not bff so fix it appropriately, I cannot see what it is in that mediainfo listing
    You cannot specify aspect ratio in VirtualDub, AVi files cannot specify aspect ratio, except DV video. DV video has 4:3 or 16:9 flag. But that is not important for that your Huffyuv avi anyway, you know what aspect ratio is and you set it up while encoding into H.264 with x264 encoder (or that batch script in this case), you specify it with that SAR parameter as you can see above, for different system PAL or NTS or 4:3 or 16:9, you'd pick up appropriate SAR value for that command line. Encoder of course does not change resolution, instead H.264 stream is flagged as anamorphic and video is shown proportionally correct during playback. Players should follow that flag.
    You insist to keep video interlaced and to not resize (anyway you should not ever resize if keeping video interlaced anyway) so that is how its done. It is flagged in H.264 stream.
    or upload a tiny bit of your Huffuv file and I try it or just do some quick fix if needed so you can just use it right away, then you can do quick test with your player if it is going to play that MP4
  19. Capturing Memories dellsam34's Avatar
    Jan 2016
    Sure, Thanks
    Aug 2010
    VidCoder has a good interface with job queueing. Why do you want to keep the interlace? Are you watching on a scanning display?
  21. It works, it is top field first, your INI could be this:
    path_temp             :C:\Temp
    x264_variables        :--crf 14 --tff --sar 16:15 --tune grain --keyint 60 --output-csp i422 --vbv-bufsize 17000 --vbv-maxrate 17000
    paste this into notepad and save it as for example PAL_huffyuv.INI, name does not matter, it just has to have INI extension,
    then you grab your huffyuv avi and this INI file, drop them together on that _avi to MP4.BAT , you get MP4 , 4:2:2 would be kept and interlacing as well
  22. you could upsample to 4.4.4 first, see https://forum.doom9.org/showthread.php?t=173005&highlight=ChromaReconstructor] Here then compress it in prorez 4.4.4 or something similar
  23. ok, my scripts use avs4x26x.exe and it all changes to 4:2:0 anyway so scratch that, it is 4:2:2 but it was converted to 4:2:0 before, I think, I might be wrong, but x264 reports it uses conversion from 4:2:0 to 4:2:2,
    but anyway, I was going in different direction, I just waited if you are going to try it before. Like JVRaines and perhaps many more think. Just use the best deinterlacer there is QTGMC and perhaps do not resize, you get 50p, you would play it everywhere and it would be unrecognizable from original, perhaps even enhanced somehow by QTGMC, you just compare it yourself. Mind you you cannot get deinterlace quality on screen the same way like QTGMC deinterlaces, so even if you manage to get true 4:2:2 and archive it, then during playback deinterlace would not be top notch. You just might have experience with bad deinterlace before or you might read old threads about simple deinterlace, not double frame rate deinterlace that keeps temporal resolution.
  24. Capturing Memories dellsam34's Avatar
    Jan 2016
    You guys are right, I may just have to de-interlace the video rather than relying on the media player chip or TV, But this is overwhelming for me, I will have to learn the scripts first after doing some reading before I open up a separate thread on how to use QTGMC.
  25. whatever you do, use the lossless mode of qtgmc..
  26. Capturing Memories dellsam34's Avatar
    Jan 2016
    It came out cleaner but lost some sharpness there, Is that due to de-interlacing?
  27. that posted MP4 , just noticed, sorry I forgot to take away that --output-csp i422 from command line, so it is 4:2:2 but it was converted to 4:2:0 before in Avisynth but x264 changed it to 4:2:2 again, so it is messed up a bit anyway
    QTGMC has lots of settings, it is like a software on its own and it uses lots of modules that that had different purposes before, it is a fine example what people do and can build upon, check this website:
    http://avisynth.nl/index.php/QTGMC#Sharpness
    scroll it up or down, it has lots of settings, I could see some source-match/lossless settings etc. but I just used this simple setting:
    QTGMC(Preset="slow")
    there is downlod button on the left, download it, unzip it, follow instructions, you can put most of the DLL's into Avisynth plugin folder, some files go into system folder, check it out over there, then you just can use my scripts adding one line into Avisynth and that's it, ..., just be prepared, it takes a time and it might use only 40-50% CPU. In that case you could just encode two videos at the same time, starting one encoding, and then the other, running two instances at the same time and CPU will be closer to 100%.
    You could use this INI:
    path_temp             :C:\Temp
    x264_variables        :--crf 14 --tff --sar 16:15 --tune grain --keyint 60  --vbv-bufsize 17000 --vbv-maxrate 17000
    Load_Stdcall_plugin("C:\..........your path here .........\plugins\yadif.dll") #this plugin needs to be loaded manually, it is not enough that it is in Avisynth plugin folder
    assumetff()
    QTGMC(Preset="slow")          #or whatever settings you come up with
    converttoYV12()                 #this converts video from 4:2:2 to 4:2:0, if QTGMC gives a trouble with 4:2:2, if some DLL's would not take it, you can put this line above QTGMC
  28. Capturing Memories dellsam34's Avatar
    Jan 2016
    I did process a video with the code you gave me and it came out 4:2:2, There is a little loss I guess due to format conversion, It looks like the video slightly darker and blurrier just tiny bit, Anyway is there a way to keep the PCM audio? Thanks a lot for the help.
    Format profile                           : Base Media
    Codec ID                                 : isom (isom/avc1)
    File size                                : 443 MiB
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 15.7 Mb/s
    Encoded date                             : UTC 2016-12-27 23:57:58
    Tagged date                              : UTC 2016-12-27 23:57:58
    Video
    Format profile                           : High 4:2:2@L3
    Format settings, ReFrames                : 4 frames
    Format settings, GOP                     : M=4, N=60
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Bit rate                                 : 15.4 Mb/s
    Maximum bit rate                         : 19.2 Mb/s
    Width                                    : 720 pixels
    Height                                   : 576 pixels
    Display aspect ratio                     : 4:3
    Frame rate mode                          : Constant
    Standard                                 : PAL
    Scan type                                : MBAFF
    Scan type, store method                  : Interleaved fields
    Scan order                               : Top Field First
    Bits/(Pixel*Frame)                       : 1.487
    Stream size                              : 435 MiB (98%)
    Title                                    : 64:fps=25.000@GPAC0.6.2-DEV-rev29-gd869dc5-master
    Writing library                          : x264 core 148 r2705 3f5ed56
    Encoding settings                        : cabac=1 / ref=3 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.25 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=6,6 / fast_pskip=1 / chroma_qp_offset=-4 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=tff / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=0 / keyint=60 / keyint_min=6 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=14.0 / qcomp=0.80 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=17000 / vbv_bufsize=17000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.10 / aq=1:0.50
    Tagged date                              : UTC 2016-12-27 23:58:03
    Audio
    Format                                   : AAC
    Format/Info                              : Advanced Audio Codec
    Format profile                           : LC
    Codec ID                                 : 40
    Bit rate mode                            : Variable
    Bit rate                                 : 256 kb/s
    Maximum bit rate                         : 265 kb/s
    Channel positions                        : Front: L R
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 46.875 FPS (1024 spf)
    Stream size                              : 7.23 MiB (2%)
    Encoded date                             : UTC 2016-12-27 23:44:24
  29. yes, sorry I explained above
    To keep PCM is not possible with that script, you just might load both videos avi and MP4 into MKVmerge and uncheck tracks you do not want to get MKV with H.264 and PCM. Do not forget set aspect ratio to 4:3 or perhaps even frame rate to 50p there. But this way, you might confuse some media players as well, not sure how many of them can play MKV container with PCM audio in it, example here:
    I just gave it a shot and encoded
    QTGMC(Preset="slow", SourceMatch=3, Sharpness=0.2, TR2=2 )
    but of course I just did a quick test, I do not know much what I was doing exactly to improve sharpness or to keep it, sharpness could be a bit higher etc.
  30. Capturing Memories dellsam34's Avatar
    Jan 2016
    Is there a script that keeps PCM audio, I don't think I'm going MKV route, I will however need to practice QTGMC, Do you have a script for just de-interlacing with QTGMC?
