I want to build a multi CD/DVD Burner with 6 burners.
At the moment I have an IDE mobo with IDE 4 burners and 2 IDE Hard drives which contain my many CD and DVD images on.
I connect with primary, secondary and a PCI controller card.
All goes well but I want to expand into another box for 6 burners.
I have the IDE mobo, burners and 2 PCI controllers but my main question is can I use 2 PCI controllers which will connect me to the 6 burners.
Also any other suggestions please.
I still use XP with Nero and not connected to the internet or anything else.
If your mobo can support it, and you have slots/racks for the drives, extra pci cards can certainly add extra simultaneous burning capability. I have put together similar 8-disc systems a while ago using ide dvd-r drives in a win98 and then later XP tower. With nero, cdrwin, discjuggler, etc.
Some suggestions:
If possible, use similar/identical models of drives. Helps with cache ram management & consistency of throughput. Similarly, use matched cards (many will cooperatively share resources if they can intimately recognise their pair"s capabilities).
If possible, sata is preferable to ide. Helps with resource configuration & buffering flow.
If possible, use Win7 64bit over Xp to ensure plenty of dedicated application memory allocation.
Strongly recommend using 2-part process of read-to-iso (save to hdd/ssd) then write-from-iso vs. Live disc-to-discs. Again, mem alloc & throughput.
Recommend dedicated read drive, on separate bus & controller from writing drives.
ScottLast edited by Cornucopia; 26th Dec 2016 at 16:30.
Btw, scsi also worked quite well in the past, both for direct-to-disc connections and for expansion chassis connections.
Scott -
Great help..many thanks..
Yes all my stuff is from iso and I will check the controllers that they are the same.. I think they are.
For me to go sata, I would need the new mobo I guess or are there small converters that will allow sata/ide ports. That way I will buy the sata burners and sata controllers.
I think I have a spare Win 7 64 which I can use too
Many thanks
Apps will write a BD-R won't write a BD-RE disc with LG multi-format burner
By brassplyer in forum DVD & Blu-ray WritersReplies: 4Last Post: 12th Feb 2015, 11:06 -
Copying DVD movies with a Sony VRD-MC6 Multi-Function DVD Recorder.. help?
By madeyeX in forum DVD RippingReplies: 14Last Post: 17th Dec 2014, 21:36 -
Combine a bunch of short promo DVD's into one multi-chapter DVD
By jsuneb in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2014, 12:18 -
Looking for build script to statically build ffmpeg, mencoder, mplayer,...
By Selur in forum MacReplies: 8Last Post: 11th Sep 2013, 16:13 -
Plextor DVD Burners?
By wulf109 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 12th Jan 2012, 18:01
