Are there any tips to improving something that was edited in a way that causes noticeable jumps in background music? I don't have the original sources and the only programs I really know how to use are virtualdub and audacity.
Results 1 to 11 of 11
Audio only or audio-with-video? Are there foreground elements on top of the bad transitions? Is the music track separate or mixed?
I'm working with something where someone tried to two scenes that had completely different background music playing and tried to make it look like one big long scene. There is a sudden jump from one piece of background music to another and it still sounds kind of distracting
Well you can't remove "background music" from any file.......so what is it you were expecting for a result?
I guess that what I want to do is insert some kind of sound effect could somehow make any sudden jump from one piece of music to another where the middle of one piece of music suddenly cuts to the middle of another piece of music sound good. Probably a sound effect that sounds like a musical instrument anyway, like a cymbal crash or something
I wouldn't punctuate the shots with percussion because then they would come across as separate takes. There's a chance that you can tone down the music with vocal isolation and then add different music or background ambience.
Even a simple x-fade transition of bkgd music @ low volume to bkgd music @ high volume will be less noticeable than a jump cut.
Scott -
Briefly cut away to something else - backstage, outside, whatever.
https://en.wikipedia.org/wiki/Cutaway_(filmmaking)
https://www.videomaker.com/article/13850-the-art-of-the-cutawayLast edited by raffriff42; 26th Dec 2016 at 16:23. Reason: linkage
You might try to find the mp3s of the exact recordings that played in the background and synchronize these mp3s to the background music. Then you can cut out the original audio where there is no speech and then play with fades of handles of the speech snippets.
a no no to a lot of audio experts, but i'd apply some heavy compression to kill the transients so that everything is loud or pretty much the same level. ffmpeg's compand can do that with points set at -72/-72 -36/-9 -3/-3 24/-3. post compression, using a db histogram will show that most of your peaks will most likely be in the -3 to -9 range.
Help with editing audio on SVP13
By melissajeand in forum EditingReplies: 3Last Post: 3rd Sep 2016, 13:30 -
Editing MP2 Audio
By ROBO731 in forum AudioReplies: 5Last Post: 4th Aug 2014, 08:05 -
Audio editing
By efiste2 in forum AudioReplies: 2Last Post: 10th Feb 2014, 16:08 -
Avisynth audio editing
By Mephesto in forum Newbie / General discussionsReplies: 10Last Post: 20th Apr 2012, 00:35 -
Editing audio on DVDs and BD
By tolson12390 in forum Newbie / General discussionsReplies: 3Last Post: 16th Feb 2012, 14:49
