I just bought the Die Hard collection on blu ray, and since I find this collection so precious I want to back up the entire collection. However I have faced problems whilst ripping the supplementary features.
What I have done is used a ripper to extract the files from the disc, so they are all now stored on my hard drive as .mt2s files. From here I have converted them all to mkv files and labelled them accordingly.
Now the actual movie files themselves have no problems whatsoever, I am having an issue with the extra features like the deleted scenes, test footage and files like that. I am facing three problems here.
When I try to view these files on my computer, they are not playing properly in the sense, that the audio is completely out of sync, there are deinterlacing issues, and lots of stuttering. To rectify this I have tried using avisynth with virtualdub but the output from virtualdub has the following issues.
2. aspect ratio different to the source
3. the outcome from virtualdub is moving much faster as you can tell, but the timestamp is the same.
I have attached both the source and the output from virtualdub to show what exactly what I mean, does anybody know how to fix the resulting file so it is how it should be. I have not included audio in the virtualdub output. I did notice that the framerate or the original is 29.970628, and in virtualdub its 25 fps, but changing this back to 29.970628 made no visible difference. I have fixed the deinterlacing issue with yadif as you'll notice as well.
Thanks in advance
My VDub shows 29.97fps after opening the Source.mkv using FFVideoSource. But it is a mess.
How about the original mt2s file? Does it show the problem? Can't you just work directly with that? Can you upload a piece of it? A much smaller piece than your earlier one will do fine, one showing steady movement.
Edit: With a little more work now, this seems to fix it:
FFVideoSource("Source.mkv")
AssumeTFF()
SelectEven()
AssumeFPS(29.97)
TFM().TDecimate()Last edited by manono; 6th Jan 2017 at 13:59.
Canopus ADVC-300 and other TBCs to die for
By Leo E. Backman in forum RestorationReplies: 22Last Post: 4th Apr 2017, 13:41 -
Projector model tracking predigital effects - links? ala Die Hard 1?
By yoda313 in forum Off topicReplies: 3Last Post: 10th Jan 2014, 06:15 -
Die Hard 25th Anniversary Edition 5 Disc Blu-ray $12.99 @ Best Buy
By louv68 in forum Off topicReplies: 1Last Post: 4th Jan 2014, 08:22 -
Backing up Hard Drive
By didikai in forum Newbie / General discussionsReplies: 10Last Post: 26th Jan 2013, 10:43 -
Backing up data from the computer hard disk to DVDs/CDs
By shashgo in forum Newbie / General discussionsReplies: 11Last Post: 27th Mar 2012, 10:17
