Hello all, and thanks for taking the time to read my little thread :)
I am relatively new to the whole VCD scene, and still have some newbie questions that I can't find answers for by browsing forums (slowly, a la dial-up) and the guides.
Basically, I am wondering if it is possible to add chapters to my VCDs using NERO as my burning program. I am unsure what version I have, but it is the newest one out, just finished installing the patch.
I was looking at a guide by Sefy, and it tells you how to add chapters by getting the info using ChapterXtractor and then burning using VCDEasy coupled with CDRDao. The problem is, I only have Nero, and the only copies to download of CDRDao were for Linux, where I am on Windows ME.
So I know of that method, but am unable to use it due to the fact I can't find CDRDao. Any input is appreciated :)
VCDEasy comes with cdrdao (get the full installation). You can burn within VCDEasy or just create the image and then burn in Nero. If you decide to go with VCDEasy and have problems with the ASPI drivers (as I did), be sure to read the FAQs that are installed with the program.
Just to add/change what gonz0 mentioned, get ASPI 4.6 (not 4.7) to make CDRDao work, and I would not recommand using Nero to burn, alot of people report problems with movies not playing back after.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Any idea where I can get ahold of a copy of the 4.60 drivers ? I have 4.7 installed on my system, and my searches are only resulting in 4.7 :(
Check the Classical Guide links at the top, it has a link to the ASPI 4.6
Best Regards,
Sefy Levy,
Mp4 (nero) with chapters
By smartel in forum Newbie / General discussionsReplies: 11Last Post: 1st May 2011, 23:50 -
Add a intro clip onto a DVD to play before chapters apear NERO VISION
By cp_ozie in forum Authoring (DVD)Replies: 11Last Post: 25th Jan 2009, 19:04 -
How do I, add chapters in Nero causing sync problem
By breeze9 in forum Authoring (DVD)Replies: 2Last Post: 22nd Jan 2008, 07:37 -
Can chapters created in Nero 6 show up in menu?
By wayney in forum Authoring (DVD)Replies: 2Last Post: 15th Jun 2007, 12:46 -
Chapters using Nero Vision?
By aelfheah in forum Authoring (DVD)Replies: 4Last Post: 8th Jun 2007, 12:40
