vhelp has that acer laptop and he has posted these sample files, you can check if it's good for your needs:
h264
https://forum.videohelp.com/attachments/40110-1483124852/video.20161230.Starwars.TFA.VI...2.60_api-1.19_[u1.br6.ref4.mkv
h265
https://forum.videohelp.com/attachments/40111-1483125415/video.20161230.Starwars.TFA.VI...2.60_api-1.19_[u1.br6.ref4.mkv
x264 crf=1 slow (basically a visually lossless replica of source)
https://forum.videohelp.com/attachments/40115-1483145866/video1.20161230.Starwars.TFA.V...0M_x264-r2338_[slow.crf1.mkv
Results 61 to 65 of 65
Thanks for the link. Down loading now.
You, know come to think about it, that ACER laptop with the HD620 is cheaper as a whole laptop then just the i7 iris 650 CPU by itself. I dont know if going from HD620 to Iris 650 is THAT big a difference ? Any thoughts about that?
This whole QS thing is fascinating. At least to me. -
I'm not sure, I doubt the difference will be that much. I know speed-wise, intel claims 12x realtime ( 2 hour movie takes 10 minutes to encode) when encoding 1080p video with their 7th generation U processor line, but their datasheet is hard for me to understand in regards to what the difference between the just released u processors and the ones released a couple months ago, maybe you can make better sense of it:
http://www.intel.com/content/www/us/en/processors/core/7th-gen-core-family-mobile-u-y-...eet-vol-1.html -
OK so i downloaded those clips.
i *THINK* i see a difference - but it could be placebo effect.
I think the QS version has a little less.....er....oomph to it, or less depth to the picture - but not much difference and certainly not for a 9" screen
Yeah, its all interesting stuff.
I am not really able to use h65 yet because the nooks cant handle it,
Lets keep watching CES to see what comes out -
Looking for build script to statically build ffmpeg, mencoder, mplayer,...
By Selur in forum MacReplies: 8Last Post: 11th Sep 2013, 15:13 -
Should a video rig be built like a gaming rig?
By brassplyer in forum Newbie / General discussionsReplies: 2Last Post: 16th Aug 2013, 01:03 -
AMD Phenom II 960T 4 Ghz 6 cores + 7950CF = CPU bottlenecked?
By Stealth3si in forum ComputerReplies: 3Last Post: 21st Mar 2013, 17:14 -
Does VidCoder.exe 64-bit is using all cores in CPU or HDD is slow?
By WuxiIxuw in forum Video ConversionReplies: 25Last Post: 1st Sep 2012, 06:18 -
First Timer..CPU Build Help.
By Texxas_Boy in forum ComputerReplies: 23Last Post: 20th Feb 2012, 20:20
