Soon my son will be opening up two of his christmas presents....a "naked" laptop and a Windows 10 USB stick.
Any advise once the laptop finds the stick?
Make a c: partition first or will Windows install do that for me?
Windows 10 will install a partition so no need to make one one,just make sure the laptop is set to boot from the usb first.
Unless something changed with Win10, it will show you the drives available (likely only 1 in this instance) and ask you how much of the drive that you want to use (ie: use the entire drive or create partitions), then it will format and install.
Google is your Friend -
the install should be fast& easy it's after that things get funky. There are many things to disable on win10 to keep to your privacy intact and to speed it up aswell.
see here*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
Composite digital signal into laptop: can't find signal stream on laptop!!
By herder in forum Capturing and VCRReplies: 19Last Post: 17th Jul 2016, 15:11 -
copy same software installation from laptop A to laptop B ?
By vhelp in forum ComputerReplies: 9Last Post: 7th Oct 2015, 13:21 -
Creating subtitles from scratch
By pboong in forum SubtitleReplies: 7Last Post: 12th Apr 2013, 02:15 -
Converters Start Conversion Process from a Scratch after Any Interruption
By ConverterCrazy in forum Video ConversionReplies: 2Last Post: 4th Feb 2013, 00:19 -
DVD Ripping with scratch tolerance - like Exact Audio Copy
By feelart in forum DVD RippingReplies: 6Last Post: 28th Oct 2012, 13:50
