    Dec 2016
    Wales, UK
    Hi, I have been successfully using VOB2MPG for some time and decided to upgrade to the Pro version. The install went fine but after I launched the application and input the registation info my Security Programme blocked the final launch and removed 2 files stating they are infected with the HEU_AEGISCS986 threat. I have attached a screen dump showing the problem. Can you please advise what I should do now?
    Thanks,
    Tony
    Feb 2006
    Make sure that your Antivirus is up to date.
    Have you tried adding the program to the antivirus exclusions list
    Dec 2016
    Wales, UK
    Yep, antivirus was updated earlier today.
    I haven't added the program to the exclusions list yet as I was wondering if a virus had crept in somewhere.
    Also I am not sure what the replacer.exe program by ChosenBytes.com was doing in the install?
    Find another antivirus program.
    I only use www.virustotal.com to scan files and some times malwarebyte anti-malware to get rid of adware crap.
