I am looking for a alternative to Freemake that is like 30% to 40% at encoding videos that has pretty close to the same output quality which free video encode do you recommend?? I like Freemake but encoding all the videos I have with it going will take a long time I just need a video encoder that a good amount faster at encoding.
You could try what Baldric suggest using the fastest settings, although the video quality might suffer. Also, Handbrake doesn't offer as many output options, nor does it edit video.
However, if you are using a laptop or a low-end desktop to do the encoding, you shouldn't expect software-based encoding to be super fast. Also, a different program isn't likely be dramatically faster using the the same type of encoding (H.264, HEVC, MPEG-2, etc.) and similar encoding settings.
P.S. Your computer details look to be long out of date. Consider editing them to reflect your present system. Current information might come in handy for some questions.Ignore list: hello_hello, tried, TechLord, Snoopy329
DegrainMed Faster Alternative for light compression artifacts in HD Videos?
By MrBiggles in forum RestorationReplies: 20Last Post: 1st Aug 2015, 18:21 -
Freemake issues - any recommended alternative?
By PhilJW in forum DVD RippingReplies: 1Last Post: 20th Apr 2015, 05:51 -
H264 video cutter with smart re-encoding (alternative to VideoRedo H264)
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jul 2014, 09:42 -
Alternative to Handbrake for x264 video encoding?
By thefinalprophecy in forum Video ConversionReplies: 37Last Post: 25th Aug 2013, 00:11 -
Looking for faster alternative to McTemporalDenoise for older VHS(Avisynth)
By VideoFanatic in forum RestorationReplies: 1Last Post: 25th Jun 2012, 20:34
