Hello everyone!
Can someone help me with recording and saving mp3 files from Napster? Would be so great! I just want to save a few track on my usb drive so I can listen to music in my car (radio doesn't work and the car is so old, doesn't pay off to buy a new radio...)
Thanks in advance!
Napster is AFAIK a subscription service so it is against forum rules to discuss/assist.
Take a look at recording software. In comparison with downloading you would move in a grey area.
There are some music streaming recorder who offer this feature. For instance audials tunebite premium.
http://audials.com/en/how_to_record_internet_radios/start.html
I'm using that since years and I'm very satisfied with it. -
For a bit advanced users, you can use Virtual Audio Cable with some audio recording software (Reaper e.g.). And you will need ASIO4ALL installed.
In Reaper, go to Audio settings and set input to ASIO. Then in ASIO control panel, set input to VAC.
In the Windows Playback Devices, set default output to VAC.
Play a song through a web browser.
In Reaper, Record arm the track and set its input to that where VAC is assigned to. If you left only VAC turned on in the ASIO control panel, this would be In1+In2.
In Reaper, press record.
These are just a broad instructions. You will probably need some more googling for every step. -
You have to check Napster's terms of service and see if they allow you to use Applian's Replay Music program with it. If it is allowed, in the settings you would choose to record in FLAC to preserve quality. Are you sure Napster still exists? What would be the point with Spotify offering a free service?
Here are the Napster Terms and Conditions:
http://us.napster.com/terms
Of particular note:
8. INTELLECTUAL PROPERTY RIGHTS
... You agree not to (i) reproduce, record, retransmit, redistribute...They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
need tool to record and save on hd from cbs.com &nbc.com
By RBCC in forum Video Streaming DownloadingReplies: 8Last Post: 19th Apr 2015, 18:54 -
Save mms wmv as an mp3
By AshleyQuick in forum Video Streaming DownloadingReplies: 3Last Post: 13th Apr 2015, 19:03 -
By RBCC in forum Video Streaming DownloadingReplies: 2Last Post: 12th Apr 2015, 02:35 -
How to record streaming flash video, edit and save as AVI, MP4, FLV,etc.
By Baldrick in forum User guidesReplies: 3Last Post: 20th Sep 2014, 14:06 -
How to record part of live stream m3u8(30min)& save it as mp4 using ffmpeg?
By spiderMan007 in forum Video Streaming DownloadingReplies: 0Last Post: 18th Mar 2013, 17:54
