Hi,
I've being asked by TNT to send them a video under this specs: XDCAM HD422 50Mbps 59,94i which I know is easily achievable with AE, Premiere or AME as a MXF container, but they are asking the file as a MOV container and I can't find any plugin, app or codec pack to do it.
Can anyone please point in the right direction?
Thanks in advance.
You need a mac to export it directly from a NLE. Also quicktime and the "MOV" container from Apple is no longer officially supported on Windows
But you can export it normally from a PC, and then rewrap it into a MOV with open source software like ffmpeg or ffmbc
Convergent design used to have a free application to rewrap MOV <=> MXF , not sure if it's still available -
It should show up under MOV export options on a mac if you have the pro video formats installed , or something like FCP/FCPX installed concurrently
https://support.apple.com/kb/dl1396?locale=en_US -
Ok this is what it was happening, since we abandoned any kind of Apple video editing/modifying workflow I didn't have Pro video formats installed anymore and I couldn't install them either so I've installed an old version of FCPX, then installed Pro video formats from the link that you posted and voila, all Pro formats are showing for export under Quicktime codecs.
I'm not sure if they are going to remain installed when I get rid of FCPX but I'll let you know here for future reference.
Thanks poisondeathray for the help.
DV to MOV container
By abross86 in forum Video ConversionReplies: 7Last Post: 17th Jun 2014, 15:15 -
Batch embed .SRT files in h264 MOV container
By brobeans in forum MacReplies: 2Last Post: 5th May 2014, 19:15 -
SONY XDCAM HD422 .MXF file and... In Sync Blade 2.2
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 2nd Jun 2013, 01:20 -
.mxf (PAL HD422) HD to SD avi
By marcorocchini in forum Newbie / General discussionsReplies: 63Last Post: 25th Apr 2013, 08:01 -
Changing Container from MOV to MP4 in bulk?
By anonymous99 in forum Video ConversionReplies: 13Last Post: 28th May 2012, 10:24
