    Jul 2008
    Singapore
    I recently upgraded to Windows 10 and Corel Video Studio Pro X9 but after installed, the program cannot initialized.
    The splash screen will start loading for 5-10min and then close but the application did not launch. I check task manger, the program is not running.
    I am on Windows 10 / 64bit
    May I know how to go about? Thx.
    And the same program - Corel Video Studio Pro X9, I install in my old PC - Windows 7 have no problem.
  2. Member DB83's Avatar
    Jul 2007
    I would uninstall it. Delete any temporary and 'document' folders and ,if possible, registry entries.
    Then re-install.
    Corel also has a dedicated forum and it may assist to register there and ask for assistance if this does not work.
