Hello Friends,
When I try to extract chapters from mkv file using gMKVExtractGUI
It gives me options:
a)XML b)OGM c)CUE
Which option should I select
and with which tool I can merge extracted chapters to any other mkv file.
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Wondershare Ultimate Video Converter can merge chapters into one video. It is not done by default. If you use Wondershare, you'll need to select that option to merge all into one video. Playback is superb.
mkvpropedit -c "chapters.xml" "file.mkv"
for normal use it generally doesn't matter which format you extract to. Only if you need specific Matroska elements in the chapters do you absolutely need XML, but I generally use XML anyway. -
Or if you actually need a GUI mkvtoolnixGUI will happily load the chapters an save them into any mkv.
If that's not enough there's chapterEditor as well.
How do I merge two MKVs into one including chapters?
By Todd Sauve in forum Newbie / General discussionsReplies: 12Last Post: 12th Mar 2018, 08:52 -
merge multiple files into MKV container, and autogenerate chapters
By axeon73 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jun 2015, 18:46 -
Merge mkv, maintain chapters
By indijay in forum EditingReplies: 7Last Post: 4th Mar 2014, 07:59 -
Chapters in mkv, in relation to DVD chapters
By indijay in forum Video ConversionReplies: 4Last Post: 3rd Mar 2014, 11:09 -
How to merge chapters in a title & How to make .IFO from .VOB
By Cyrusorc in forum Newbie / General discussionsReplies: 4Last Post: 11th Jul 2012, 21:14
