    Sep 2016
    Netherlands
    The .srt subtitles that I have has sentences on the same time, like this:
    99
    00:06:03,160 --> 00:06:06,800
    Test1
    100
    Test2
    The problem is that both VLC as MPC-HC first show 100 and then 99, like this:
    Test2
    Test1
    How can I solve this? Modifying the .srt subtitles by hand isn't an option as I'm talking about more than 1000 .srt files.
  2. You have overlapping timecodes.
    Subtitle Edit -> Tools -> Fix common errors.
  3. Marsia Mariner
    Guest
    Change to something like this:
    99
    Test1
    Test2
    By finding a better source for the .SRTs that you use
    Overlapping timecodes are OK in (properly-authored) .SSA and .ASS, but are not OK in .SRT files.
    Sep 2016
    Netherlands
    99
    Test1
    Test2
    There isn't a better source as these CC are ripped from a television VOD service. I converted them from TTML to SRT as no non-web video player seems to support TTML subtitles.
    Sep 2016
    Netherlands
    But then the subtitles aren't in sync all the time. Is there some way to merge them or just play by line?
  6. Subtitle Edit -> Tools -> Merge lines with same time codes...
