  1. I want to sync 4 HD video clips to one UHD(4K 2160p), i use script , but every clip not play same sync: see pic
    http://www.imagebam.com/image/bcc135521383970
    After that to encode to hevc or .. 2160p
    Avisynch sript:
    TR=directshowsource("UHD-Top_Right.ts")
    TL=directshowsource("UHD-Top_Left.ts")
    Top=StackHorizontal(TL, TR)
    BL=directshowsource("UHD-Bottom_Left.ts")
    BR=directshowsource("UHD-Bottom_Right.ts")
    Bot=StackHorizontal(BL, BR)
    StackVertical(Top, Bot)
    All 4 video clips info:
    Video
    Menu ID : 202 (0xCA)
    Format : AVC
    Format profile : High 10@L4.2
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : 27
    Duration : 2 h 24 min
    Bit rate mode : Constant
    Bit rate : 17.8 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 50.000 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 10 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.172
    Stream size : 17.5 GiB (95%)
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
  2. Do not use DirectShowSource, better use LWLibavVideoSource.
  3. If the four videos don't start at the same frame use Trim() to remove initial frames. For example,
    TR = LWLibavVideoSource("UHD-Top_Right.ts").Trim(5,0) # remove first five frames
    Do that for each clip that needs it.
