I use WDTV Live boxes, but need to find another inexpensive player that can utilize a Comcast remote.
Just something that will play mpeg2 and mp4 videos from a usb flash drive.
My suggestion would be to go the other way and get a programmable remote for the same money ($30-$40) you'd spend on a media player. Your Comcast remote will probably be a preset option and the WDTV remote can easily be added.
I've decided to try an auto HDMI switcher that accepts the last input turned on. Hopefully, when the WDTV is turned on, its input will override the cable box. When turned off, the cable box will be used. (Only $8 to find out). I have a very simple WDTV remote, so maybe that will work out. If not, will have to get another Harmony.
Simple Hardware Media Player ?
By PowerFalcon in forum MediaReplies: 3Last Post: 22nd Jul 2015, 23:58 -
will the hdpvr2 work with the newer comcast dvr's that lack component out?
By yoda313 in forum Capturing and VCRReplies: 15Last Post: 14th Mar 2014, 19:49 -
Can't get new version (1.7.2) of Media Player Home Cinema to work!?
By jgg in forum Software PlayingReplies: 10Last Post: 3rd Feb 2014, 19:26 -
Make subtitles work with media player classic
By arnie22112000 in forum SubtitleReplies: 27Last Post: 6th Sep 2013, 21:00 -
subtitle doesn't work with windows media player!!!!
By showel in forum SubtitleReplies: 3Last Post: 5th Jun 2013, 14:31
