  1. Hi. Regarding the attached screenshot - does it matter which PGC I select given that both PGC1 and PGC2 are the same length (and therefore the same content)?
    Why are the two options if they're both the same? Thank you.
  2. Are you trying to decrypt a complete DVD to your hard drive? If so, select File Mode and not the default IFO Mode.
  3. Maybe they aren't the same? Check the chapters and cells within them have the exact same vob/cell ids - they probably don't.
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Who was that masked man?!?
  5. manono - the DVD contains 3 different 'shows' and, ultimately, I want a separate file for each. IFO seemed the best way to go.
    LIGHTNING UK! - too late, I've ripped it now. And I know it's good as I watched it via a DVD player first.
    Thanks guys.
