Hi everybody,
I have MeGUI 2624 x86 work in windows server 2012.
I create multiple avs files over 100 files, i would like to add in MeGUI one time.
when i add avs file one by one in MeGUI , i click on AutoEncode to create the videos.
is it possible add multiple avs files once in MeGUI ?!
The OneClick encoder does batch encoding and it has no problem using existing Avisynth scripts for the source video. You'd just need to create a OneClick preset that disables any automatic cropping or resizing etc. If anamorphic encoding was enabled when the scripts were created, it should use the aspect ratios added to the scripts.
how to add multiple audio tracks to .mpg files
By basha11 in forum Newbie / General discussionsReplies: 4Last Post: 16th Mar 2016, 02:35 -
Need help, encoding not working while charging avs script (MeGUI)
By bel57 in forum Newbie / General discussionsReplies: 14Last Post: 14th Dec 2015, 16:41 -
megui cant open avi/avs file
By anime12345 in forum Video ConversionReplies: 9Last Post: 2nd Jun 2015, 17:07 -
How To Improve Quality Using MeGUI / AVS Script
By Suwadith in forum Video ConversionReplies: 12Last Post: 2nd Feb 2014, 15:10 -
MeGui: AVS script creator problem
By Fed03 in forum Newbie / General discussionsReplies: 5Last Post: 23rd May 2013, 11:02
