I want to cut MKV files with FFMPEG.
I used the following syntax:
But it gave me a file that starts with a black screen and only sound.Code:ffmpeg -i input.mkv -ss 00:16:42.752 -codec copy -t 71 -s 700x394 out.mkv
According to the info FFMPEG showed the video codec was h264.
So i went and changed it to this:
Also tried with:Code:ffmpeg -i input.mkv -ss 00:16:42.752 -c:v h264 -t 71 -s 700x394 out.mkv
Now it worked and there was no black screen, but the video quality is not the same.Code:-c:v libx264.
Is there something else i should add or change in order to make the cut version the EXACT SAME QUALITY as the original file?
Not better quality.
Not worse quality.
The exact same as the original file.
anything about how to keep the quality.users currently on my ignore list: deadrats, Stears555
problem with ffmpeg - cutting video and merging audio tracks
By yakov in forum EditingReplies: 0Last Post: 23rd Mar 2016, 12:00 -
Are acceptable resolutions based on video encoder or video format (ffmpeg)?
By alexander121 in forum Video ConversionReplies: 2Last Post: 17th Dec 2015, 10:45 -
FFMpeg Presets for Video Format/Quality and Device (Iphone,Ipad e.t.c.)
By alexander121 in forum Video ConversionReplies: 2Last Post: 25th Nov 2015, 03:25 -
How to cut video with ffmpeg with the same quality without reencoding
By alexander121 in forum EditingReplies: 6Last Post: 8th Dec 2014, 02:36 -
php - How to use ffmpeg converting video without decreasing of quality
By hno2005 in forum Video ConversionReplies: 8Last Post: 13th Apr 2014, 16:11
