    Dec 2016
    There was a fan edit of the phantom menace called "The Phantom Edit" . its dvd quality and interlaced so I was wanting to make the same cuts with the bluray version of the movie but when i looked at the .vob files they where 29.97 fps while the movie is 23.976. I used Adobe media encoder and converted it to 23.976 fps but when I sync the 2 files in premiere pro cc 2017, they will slowly drift apart. Im trying to use the audio of "The Phantom Edit" as he had some music changes and blended tracks together at the cuts he made.
  2. Try to IVTC the vob to 23.976. Slow down movie from 24 to 23.976 to match. (Or slightly speed-up IVTC's vob to 24)
    Dec 2016
    vlc shows the bluray and my converted vob to both play at 23.976024
  4. There's no guarantee the Bluray and DVD versions are exactly the same. If they're edited slightly differently the audio won't stay in sync even if the frame rates are the same. It only takes an extra frame at a scene change here and there.... that sort of thing.
  5. Correct numbers are 30000/1001 and 24000/1001 and in such way they need to be expressed.
  6. Mr. Computer Geek dannyboy48888's Avatar
    May 2007
    Texas, USA
    I've seen bluray and DVD cuts of the same film do that. Part of it is on purpose to deter pirates from pasting the non cinavia DVD audio with a bluray cinavia video. You may have to manually cut frames out periodically on the movie ( probably at scene changes) to maintain A/V sync
    if all else fails read the manual
    canada
    They are including cinavia on dvd for the same reason so audio can't be replaced.
