  1. After 21 days, anyDVD expires. Is there a way to continue using it for free?
    canada
    Pay for it.
    Aug 2002
    South Florida
    Second!!
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Ditto
    Aug 2006
    If you want something that you can continue using for free, you need to forget about AnyDVD.
    DVDFab Passkey Lite is free, but has fewer features than the paid version of DVDFab Passkey and cannot deal with every form of Blu-ray copy protection. MakeMKV, which can copy the contents of most Blu-ray discs to your hard drive using backup mode, is free while in beta, but requires updating the key every 60 days. Take your pick.
    Mar 2006
    No-pay for a license-either time limited or lifetime. It is well worth it. Why do you think you should be able to use it for free after the trial period.
    Go ahead and try some of the crackers found and hope your credit card and personal information is not stolen from your computer and your computer doesn't catch fire and bur your house down.
  7. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    Has this happened to you?
    'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
