  1. I upgraded Format factory from 3.95 to 4.0.0.0. Now when I convert dvd video to mp4 it fails. Drop back to 3.95 it works fine. I have attached the settings I always use.
Name:	Format Factory settings before error.jpg
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Newer isn't always better.
    If it ain't broke, don't fix it.
    etc etc etc
    Aug 2013
    Central Germany
    In addition, isn't Format Factory among the possibly spyware installing software VideoHelp warns about? There is technically better and truly free software.
    Nevertheless: "It fails" is not a sufficient description of the problem. We need to know how it fails to investigate the reason and suggest a possible solution. Does it provide a detailed log? Or at least a verbose enough error message?
