I installed AviSynth 2.6, and downloaded FFMS2 version 2.22. I copied ffms2.dll, FFMS2.avsi and ffms2.lib files to the AviSynth plugin directory. When I try to use it and opening a video file, I always get an avisynth error message: "There is no function named FFVideoSource". When I try to import the plugin explicitely, I get an error message "ffms2.dll isn't an AvisSynth 2 plugin".
If I use version 2.17 of FFMS2, and I do the same abovementioned scenario, it works properly, video opens. Has something changed in the usage between the two versions? Releases above 2.22 contains the "clang" abbreviation in their names, does it mean something special?
Latest Release:
https://github.com/FFMS/ffms2/releases/tag/2.23
Use ffms2.dll from the x86 folder -
No, I forgot to mention that I am on Arch Linux, I don't have Windows installed at all for years, but either AviSynth or FFMS2 worked well with wine. I just had to copy avisynth.dll and devil.dll to the actual folder, as I have a headless VPS with no graphical interface to install AviSynth properly.
I would like to try out this new FFMS2 version because I read somewhere it can read media files from direct http links too, without downloading.
[avisynth] FFMS2 version 2.22 get green colors
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 16th Oct 2015, 12:04 -
what is the latest ffms2 for avisynth?
By marcorocchini in forum Newbie / General discussionsReplies: 4Last Post: 17th May 2015, 07:43 -
x264 What is the difference using raw input vs. AVS script that uses FFMS2?
By kotuwa in forum Video ConversionReplies: 6Last Post: 6th Nov 2014, 07:58 -
what is the latest ffms2 ffmpeg 32bit plugin for avisynth?
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 23rd Aug 2014, 17:11 -
Avisynth/FFMS2 error: video track is unseekable
By marcorocchini in forum Newbie / General discussionsReplies: 97Last Post: 19th May 2014, 08:24
