Hello,
I have some H.265 files that I want to convert to MPEG-4 so I can play them. I installed Handbrake 0.10.5.0, but after selecting the input and clicking Start it completes in about 1 second and doesn't produce the output file. The Activity Log has a lot of stuff, including multiple:
dxva2xFindVideoServiceConversion failed
Warning: Could not read data for preview 1, skipped
I can't tell what has gone wrong. Then as a test I tried an MP4 file that I can play and has no problems as far as I know, but the conversion also finished quickly and created no output file. Once it decided the input was a file/stream the log shows:
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'C:\Users\User\Videos\CB(Live on KEXP).mp4':
Metadata:
major_brand : mp42
minor_version : 0
compatible_brands: isommp42
creation_time : 2014-08-17 02:14:00
Duration: 00:45:09.62, start: 0.000000, bitrate: 1612 kb/s
Stream #0.0(und): Video: h264 (High), yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 1417 kb/s, 23.98 fps, 24k tbn, 47.95 tbc (default)
Stream #0.1(und): Audio: aac, 44100 Hz, stereo, fltp, 191 kb/s (default)
Metadata:
creation_time : 2014-08-17 02:14:13
[09:03:02] scan: decoding previews for title 1
[09:03:02] scan: audio 0x1: aac, rate=44100Hz, bitrate=191999 Unknown (AAC) (2.0 ch)
[09:03:02] scan: 10 previews, 1280x720, 23.976 fps, autocrop = 0/0/0/0, aspect 16:9, PAR 1:1
[09:03:02] libhb: scan thread found 1 valid title(s)
Again I can't see what's wrong. Any suggestions?
I disabled QuickSync Decoding, but that didn't work. The only other option in Video is DXVA Hardware Accelerated Decoding. It was off but I tried it on and it didn't help either.
Is an experimental version in 'nightly' likely to work if it won't convert what seems to be a routine MP4 file?
I just downloaded an MPEG-1 file from the Hubble Space Telescope website and it failed on that as well. -
I know I had this problem with my old graphics card (ATI 4670) and one of the Handbrake 10 versions, causing it to output instantly with a empty file. Filed a bug report on Handbrakes website but it never really went anywhere. Might try Handbrake 0.9.9, but it probably does not have H265 decoding support. Might also try VidCoder.
DVD ripped using handbrake/anydvd won't play
By Noquestionisdumbright in forum DVD RippingReplies: 24Last Post: 7th Aug 2015, 16:39 -
Handbrake compresses the video, but it won't load to youtube
By SunnyEarther in forum Newbie / General discussionsReplies: 5Last Post: 23rd Nov 2014, 02:14 -
Handbrake encode won't start - one particular file
By Stuckster in forum Video ConversionReplies: 18Last Post: 23rd May 2013, 06:26 -
Bought a LG Internal Blu Ray, installed it, but won't play correctly
By Sinatrafan in forum DVD & Blu-ray PlayersReplies: 17Last Post: 15th Apr 2013, 17:38 -
XP Ho won't see the other drive where Windows 7 is installed (in dual boot)
By edong in forum ComputerReplies: 3Last Post: 29th Dec 2011, 16:05
