Hi
I am a real novice here but value your input; sorry for the long post
I record on a Sony HD handycam in AVCHD either 16M (FH) 1920x1080 or 9M(HQ); it also has Sd record.
I have just gone over to a Macbook pro & am missing the ease of the sony dvd producing software.
I want to produce dvds to play on my standard dvd player (& have just started looking at Hdmi streamers to view on my tv, but may not pursue this).
I am wondering what format, specs etc I should convert the clips into (as I can't utilise hd on a dvd player) while maximising clarity.
I have produced 1 dvd using imovies9 (as I want a dvd menu giving chapters with descriptions, so I can go to certain clips). However I don't want to do any editing / effects, I just edit on camera.
I used idvd to burn; the disc is watchable but rather fuzzy.
I am happy to buy a conversion app (I have considered iskysofti Media Converter Deluxe for Mac? - reviews look good)do I need a different burn app?
So what format should I convert avchd into to maximise quality (with smaller if poss file size) someone suggested divx?; what size eg ? a x b?
Any other help please; thank you
You might take a look at the upper left on this page for 'WHAT IS' DVD.
This has information for the DVD specification, format and structure of DVDs.
Generally with a DVD about 1 -2 hours of video will give you good quality.
Since you are now a Mac user, probably better posted in our Mac Forum. Moving you.
And welcome to our forums.
Thank you redwudz; I will read the what is section; please can you link me to the mac forum
thanks -
https://forum.videohelp.com/forums/17-Mac
You also might find some useful info from the 'Stickies' at the top of that forum.
How to Create Scrolling Subtitles on my Videos?
By devilcoelhodog in forum SubtitleReplies: 6Last Post: 7th Dec 2013, 09:17 -
Batch create single frame videos
By moosehunter in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2013, 22:14 -
Slow motion videos- how to create some sections
By doggieusa in forum EditingReplies: 3Last Post: 10th Dec 2012, 18:42 -
Noob looking for advice on videos
By HeidiLynn in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2012, 07:11 -
Short Videos into a DVD - How to Create it?
By devilcoelhodog in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2012, 18:11
