I'm trying to make the best possible quality digital transfers of my old concert DVDs in order to playback on streaming media (i.e. Apple TV). I have the same DVD concert release in both NTSC and PAL format. I realize there's some art and some science to this, but I'm trying to figure out which to start with and what deinterlace / detelecine settings to use on either to produce the best result.
Here is the first :59 seconds of the video, from both sources:
NTSC: https://www.sendspace.com/file/sxjzlx
PAL: https://www.sendspace.com/file/kourwn
I'm a newbie to DGIndex, but it's indicating that both the NTSC and PAL DVDs are Interlaced. I definitely see the interlacing in the NTSC clip, and it appears to be a 5i : 1p telecine pattern (although, the 1p frame isn't entirely convincing - there are some minor horizontal artifacts), possibly indicating that the NTSC DVD is telecined PAL content? On the PAL source, it looks much more like progressive content, although I think I can see some minor horizontal line artifacts.
Is it possible that the PAL source is somehow telecined and/or interlaced, as DGIndex indicates? If so, does this imply or indicate that the original source was film and that I can somehow return to that framerate (using either the PAL or NTSC DVD)? Is there a clean method of reverting PAL --> film (23.976fps [24fps]) using AVISynth, or any other method?
I've done some NTSC Video (29.970fps) to NTSC Film (23.976fps) conversions using TIVTC... Is there a similar method approach going from PAL?
Then, again, I could be wrong: perhaps the NTSC is truly straight up Interlaced video, and the PAL is some adaptation from it (30fps source material)?
thanks in advance!
The PAL source is encoded interlaced but the frames are progressive. Just handle it as progressive video. If you think it should be 24p just use AssumeFPS(24). You'll have to adjust the audio length if you do that.
The NTSC source is field blended from a progressive PAL source (no change in running time or audio pitch). You could restore the the original frame rate with QTGMC().SRestore(). But why bother since you have a better PAL source.
detelecine/deinterlace options for NTSC DVD: 1 progressive to 5 interlaced?
By U2Joshua in forum Video ConversionReplies: 29Last Post: 9th Dec 2016, 12:38 -
Ripping DVD's - Why DeInterlace? They were 23.97 or 29.97 fields per second
By SyncroScales in forum DVD RippingReplies: 10Last Post: 16th Jan 2015, 04:07 -
Ripping NTSC DVD that was originally filmed as PAL
By chris1379 in forum DVD RippingReplies: 2Last Post: 19th Jan 2014, 23:03 -
DVD PAL to NTSC - Deinterlace, Resize, Filters!!
By Cauptain in forum DVD RippingReplies: 12Last Post: 10th May 2013, 06:36 -
DVD source quality. PAL vs NTSC
By ffxdean in forum Video ConversionReplies: 1Last Post: 6th May 2013, 11:06
