  1. when i'm trying to make my chicken run divx with subtitles i do so: 1) convert my *.sub to *.srt 2)then convert *.srt to *.ssa 3)then i open virtualdub and select frameserve , do those rename things and press ok but the numbers wont go forward
    what to do
    P.S Once I Got my shrek with subs done so : i did all those things , the numbers didn't go on but when i opened the shrek movie with right click(i have picaview) the numbers started to change - but not this time
    help help help help help help help help help help help help help help help help help helphelp help helphelp help helphelp help helphelp help help
    Mar 2002
    chicago
    if you have .ssa files, you might want to try using avisynth instead of virtualdub...check out this post:
    http://forum.vcdhelp.com/viewtopic.php?t=85367&highlight=
    --it works great for me
    Feb 2001
    Berlin, Germany
    Update! Vobsub comes now with Textsub, so you can work with *.ssa scripts in Avisynth itself. No need to use a VirtualDub filter any longer. If your source is YUY2 you will notice the speed increase.
    Check the user guide section.
    Mar 2002
    chicago
    Thanks for the info
    wish I would have known that last night...I just started an encode using the VD_subtitler w/avisynth
    oh well...
