I am transferring from Hi8 video to digital using Roxio Video Capture USB and my old video camera. The process has gone smoothly but I just hit a snag.
My older camera "failed" back in the day and started recording all the video in black and white. Once I discovered it I bought a new camera. However, I have hours of tape recorded in black and white. The capture software that came with the interface, Roxio Easy VHS to DVD3, won't capture the B&W feed. It will display the B&W video for a second or twothen it goes blank and states "No Video Signal"
Can anyone recommend a setting in the capture process that will allow it to capture the B&W video? If not, how about different capture software that will do so. I can say I have tried Corel VideoStudio Pro X7 and it does not recognize the Roxio capture hardware.
TIA, Steve
	Likely a hardware rather than software problem. There may be other irregularities in your monochrome signal that the converter won't handle. Add a TBC/frame sync or DVD recorder in passthrough mode ahead of the converter. Search this forum and you will find specific recommendations.
	Agreed. Since a standard color signal = black & white signal + color difference/enhancement info, and if you have been successfully viewing b&w for a while, that should just mean you have b&w + 0 color (or inadequately retrieved color info).
 Try playing with different playback equipment to rule out bad interchange, bad playback amp, bad port. Then add tbc if necessary.
 At very worst, you should still be able to to a "shoot the screen" method if the output is truly nonstandard to the point of non-capture-ability.
  S Video in Black and whiteBy FreeFall in forum Capturing and VCRReplies: 13Last Post: 29th Aug 2014, 11:54
  NTSC Footage from Japan capturing in Black and WhiteBy JawsTDS in forum Newbie / General discussionsReplies: 11Last Post: 30th Apr 2013, 23:39
  Video only has black, white, cyan, and pinkBy videohalp in forum Software PlayingReplies: 4Last Post: 10th Nov 2012, 08:48
  only black & white from S-VideoBy Victor Hen in forum Newbie / General discussionsReplies: 11Last Post: 23rd Jul 2012, 21:40
  S-Video to RCA with black and white outputBy faoltaem in forum Newbie / General discussionsReplies: 0Last Post: 4th Mar 2012, 04:50
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
