Hey there,
I have this video file on .ts format.
It contains advertisements at the beginning and the end. In addition, audio is somewhat faster than the video.
Here what I did:
1. I trimmed out the necessary part using Avidemux. It seems to recognize and cut i-frames correctly with Ffmpeg.
2. I delay the audio to 100ms using Ffmpeg command line.
ffmpeg.exe -i [input.ts] -itsoffset 0.1 -i [input.ts] -vcodec copy -acodec copy -map 0:0 -map 1:1 [output.ts]
3. Video played okay but playtime was incorrect. Playtime shown in the media player was shorter than the actual content.
Regardless of its playtime, it continued to play till the end.
Please advise me if I did something wrong.
4. Alternatively, I used eac3to to demux the file, and mux that into MKV container.
While splitting and muxing it, MKVToolnix seems to fail to delay the audio properly.
Any suggestion?
Here's the Mediainfo of the original.
General
Complete name : D:\W**.ts
Format : MPEG-TS
File size : 17.3 GiB
Duration : 2 h 0 min
Start time : UTC 2014-07-26 20:14:35
End time : UTC 2014-07-26 22:14:55
Overall bit rate : 20.6 Mb/s
Network name : D**
Original network name : A**
Video
Menu ID : 192 (0xC0)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Codec ID : 2
Bit rate mode : Variable
Maximum bit rate : 24.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Scan order : 2:3 Pulldown
Compression mode : Lossy
Time code of first frame : 14:14:15:10
Time code source : Group of pictures header
GOP, Open/Closed : Open
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format profile : LC
Muxing mode : ADTS
Codec ID : 15
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 spf)
Delay relative to video : -264 ms
Menu
List : 576 (0x240) (MPEG Video) / 577 (0x241) (AAC) / 326 (0x146) (ARIB STD B24/B37)
Service name : W**
Service provider : W**
Service type : digital television
Hi,
You may try to sinc play time with VLC.
You play the video and press J to go forward and K to go backward.
Each hit will move the sound by 50 ms.
When you feel you're synchronized ,just re-record your video.
To do so: Click on View/advanced controls.
A brand new recording button will appear to you.
Set up the destination file, first. Tools/preferences/readings-codecs/capture files.
P.S. The names of the tabs and descriptions might be slightly different as my VLC version is in French. -
TSDoctor will demux it for you and eliminate any transmissions errors, same for VideoRedo Suite....... just *might* be ok in the free program ProjectX altho the bit rate might defeat it. You can get trial versions. Also Womble will edit and or demux altho you will lose subtitles if that's important. TSDoctor is the best IMO especially since MPEG4 was introduced into Australian TV, prior to that I used ProjectX for tracks similar to yours but at a lower bit rate.
Freeware that can direct stream cut VOB/MPEG video files?
By kingmustard123 in forum EditingReplies: 28Last Post: 23rd Nov 2016, 10:17 -
DVD to mp4/m4v to sync additional audio to the video... Settings advice?
By nobodyhome in forum DVD RippingReplies: 5Last Post: 12th May 2016, 15:28 -
Please advice: edited video's audio is out of sync
By gam2029 in forum EditingReplies: 6Last Post: 5th Dec 2013, 15:14 -
audio sync problem - progressively out of sync during playback - MPEG 2
By TheShortStraw in forum Newbie / General discussionsReplies: 4Last Post: 20th May 2013, 08:36 -
Final Cut Express audio sync
By EagleAye in forum MacReplies: 4Last Post: 24th Apr 2012, 19:39
