racer-x, do you know how you can increase the speed exponentially? I noticed when using the vplay start 100 and end e.g. 200, it does not do anything. Tried all the options under vplay but none did anything. I know you can speed it up with the start values only, but that is not what i need, i want it to go faster and faster and faster untill the end.
If you want me to ask this question in the general tips thread (where i looked for this answer already), please say so and I will move it there.
Cheers.
				Results 31 to 41 of 41
	Thanks, I'll give it a go
 Update:
 Tried it for about an hour, does not do me any good, or I am not doing it right.
 Put the time layer on top of the testmovie, made sure it was included under it.
 It seems to act like a timelapse where you can skip to a certain frame, however i do not see the length of the video changing so I'm not sure how it can go faster. If it goes faster, it should decrease the time the video takes like with vPlay, correct?
 Is there no manual available where it explains some basics like this? I'd like to know what certain icons mean as well, since clicking them did not enlighten me a lot
 (like the camera icon on the upper left corner inside video editing (i do understand the clipping mask). I'll go read up on the 22 page long other thread...Last edited by kimmyk; 19th Dec 2016 at 04:37.
 No english manual... there are a lot of things you just fiddle with and figure out. Most english users are probably just scratching the surface. The LUA scripting looks very versatile for example but I don't know how to use it
 Anyways you nest the accelerated scene back into the root scene
 e.g In scene 1 you put your time control object with the layer that you want to "speed" up . Set the position parameter to "acceleration" tweening. When set to "acceleration" it will speed up the decimation instead of a linear rate. Set a position "midpoint" (ie. "keyframe") on the time control layer , somewhere on the layer, with it set from 0-100 (ie. all frames included) . Slide the midpoint (keyframe) marker down until you get what you want . The 1st part will be a repeated 1st frame until the "midpoint", but the "2nd half" will be time compressed / sped up according to the interpolation parameters set, and where you slide the marker. The more to the right, the faster the speed (more frames dropped). So back in the root scene, you trim off those repeated frames from your nested scene 1 and reposition the layer where you want . There might be a graphical curve control using a spline (in one of the interpolation options there is a bezier option), but I'm not sure how to use it . There are also free 3rd party speed control options with curves/graphs for control (e.g. slomovideo) where you can ramp up /down with complete control . There are commercial options as well, but I won't go into those here
	Here is a quick ScreenCast tut on how to use TimeControl with Midpoints. My Aviutl may look a little funny because I'm running it in Linux. Right-Click to add MidPoints (aka key-frames). Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
	Thanks both.
 Anyone care to tell me how to add these 3rd party options? I tried to install the sand effect last time and that does not show up anywhere either:/
	One more thing I just cannot find anywhere in the settings: can you change the background from black to another color? Or do you have to place an image there with the color?
 Did you mean the preview, or actual background ?
 The actual background is not really "black", it's "transparent" . It just looks like "black" in the preview because a monitor cannot really show "transparent" - you can't "see" it Other programs like after effects, photoshop etc... can toggle a transparency grid but I don't think aviutl has that. But it's simple enough to make your own Other programs like after effects, photoshop etc... can toggle a transparency grid but I don't think aviutl has that. But it's simple enough to make your own
 You import an image or video BG, or you can generate a BG within aviutl as well . If you wanted a solid color , right click on the adv editing timeline => new media object => graphic => set the settings to "background" and select the color
  vsdc editor helpBy loki1143 in forum Newbie / General discussionsReplies: 11Last Post: 16th Jun 2017, 14:47
  VSDC qualityBy grendel54 in forum EditingReplies: 0Last Post: 28th Oct 2016, 20:40
  VSDC Editing helpBy Irfaankahan in forum EditingReplies: 2Last Post: 7th Apr 2016, 04:04
  vsdc basic help pleaseBy dipr in forum EditingReplies: 3Last Post: 3rd Nov 2015, 17:30
  VSDC help ?By xmadnez in forum Newbie / General discussionsReplies: 1Last Post: 30th Mar 2015, 14:14
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
