I've got an old version (2008) of WM Capture. Back in 2008, that program was interesting but basically useless because very few computers/internet had the power to play and record video streams without constant pausing and stuttering. Enter 2016, and even public library computers can screen capture videos without any problem.
The WM Capture company has been making screen capture software for a long time, so I would think they have the best software to do this kind of thing. I was looking at the changelog for their versions, and I noticed around 2012 and later their software would capture HD video streams. Then they came out with another innovation that allows you to capture the video when the window is minimized. This is supposed to use less CPU power.
Their latest version (trial ware) allows you to record for 2 minutes. Unfortunately, the newer versions won't work on the public library computers, (program crashes when trying to record) so I have no way to test it.
My question is this: Does somebody have the new version of this software (pay or trial) on their computer? How well does it capture today's streaming (SD and HD) videos?
You could try Bandicam to record the screen.
But if you want to capture streaming video I recommend Tubedigger.
General questions about playing torrent video that is 95.3% downloaded
By jimdagys in forum Software PlayingReplies: 2Last Post: 2nd Dec 2016, 15:51 -
do you have to pay in order to get spectacular video capture quality?
By uglijimus in forum Video Streaming DownloadingReplies: 7Last Post: 8th Sep 2016, 15:08 -
Look for suggestions for screen capture software?
By Tearren in forum ComputerReplies: 9Last Post: 27th Jul 2015, 23:04 -
I have some questions about video in general.
By paddlepop in forum Newbie / General discussionsReplies: 3Last Post: 16th May 2012, 15:20 -
General Enquirey - Pinnacle Video Transfer USB 2.0 Capture Device
By kato2010 in forum Capturing and VCRReplies: 2Last Post: 11th Feb 2012, 06:53
