I have various avi, mpg, vob, mp4, wmv, files in a folder. and i want to change them to mkv container (no re encoding).
How can i do that?
pls suggest me some .bat file or any other tool which can do this job.
i tried MKVBatch but its not working with vob files..
thank you in advance.!
for %%a in (*.*) do mkvmerge -o "%%~na.mkv" "%%a"
or
for %%a in (*.*) do ffmpeg -i "%%a" -map 0 -c copy "%%~na.mkv"
But:
1. mkvmerge doesn't read wmv, don't know about ffmpeg's mkv muxing abilities
2. splitted VOBs might require special handling (binary split requires binary merge)
3. what are you trying to achieve? Make compatible with your mkv hardware player? You will probably not succeed without re-encoding. I recommend against this repacking. -
thanks for your help...
your code work great.
although....
1. mkvmerge is not able to change mpg and wmv. other works fine.
2. ffmpeg is not able to change mpg. other works fine.
3. avidemux is able to change mpg to mkv but outputed mkv have changed width height ratio.i dont know why.
now the problem had solved but only one problem remains.... .mpg
i dont know that how to change mpg to mkv in batch mode.?
pls help me with that...
and i want to change to mkv bcoz the video i have are music videos.. and most of them have 2 tracks (dts, ac3) of audio.i also made their subtitles files.so i think it will be easy with mkv for stripping additional audio tracks and merging subtitles in batch mode with some .bat files.
Batch convert 4K videos
By andwan0 in forum Video ConversionReplies: 2Last Post: 19th Oct 2016, 08:27 -
Batch Convert Videos in Different Resolution with Handbrake
By Ghaldszar in forum Video ConversionReplies: 2Last Post: 7th Oct 2013, 12:44 -
Batch Convert iPod Videos?
By DavidA in forum Video ConversionReplies: 2Last Post: 16th Aug 2013, 07:03 -
Batch replace first 20 seconds of about 50 MKV-Videos
By Vlaves in forum EditingReplies: 2Last Post: 3rd Apr 2013, 06:52 -
Convert 10bit MKV videos in to 8bit MKV with XMedia
By RaW D Coy in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2012, 13:10
